What I need is when I press button2, I want to increment after 0.5 seconds the numbers shown at two 7-segment displays.
The code that I am using is below. When I press button2 it is incrementing very fast both digits.
Then change your main program so it's similar to this:
int8 increment = 0;
wait_for_keypress();
increment++;
// Put the 7-segment code here.
nina
increment
Posted: Wed May 19, 2010 5:00 pm
Thank you for all responses...the way I solved the problem was:
while (input(button1) == 0)
output_b(dezena[vdezena]);
delay_ms(5);
output_b(unidade[vunidade]);
delay_ms(5);
if (input(button2) == 0)
a++;
if (a == 50)
incrementa = incrementa +1;
vdezena = incrementa/10;
vunidade = incrementa - (vdezena*10);
delay_ms(5);
delay_ms(5);
a = 0;
It is working but I would like to know if there is another way to do this...
tks again
nina
nina
increment
Posted: Sat May 22, 2010 1:55 pm
What is the way and/or hardware that I can use to "save" some pins at PIC when using 7 segments display?
Suppose I need use 6 display 7 segments. How to "save" pins at PIC?
Thank you
Nina
Posted: Sat May 22, 2010 2:04 pm
I think you are asking how to multiplex the pins on one 7-segment display.
Normally, the multiplexing is done with several displays. 7 pins are used
on the PIC to display the segments. Then other pins on the PIC are
used to enable each display (each digit).
Scroll down to Figure 6 on this webpage. It shows how to connect the
wires.
http://www.melabs.com/resources/articles/ledart.htm
Is this what you really want to do ?
nina
multiplex
Posted: Sat May 22, 2010 3:41 pm
That is what I am looking for...
Where can I find some examples (CCS) about multiplexing 7 segment display.
