increment
nina
increment
PostPosted: Sun May 16, 2010 9:02 pm     Reply with quote
What I need is when I press button2, I want to increment after 0.5 seconds the numbers shown at two 7-segment displays.
The code that I am using is below. When I press button2 it is incrementing very fast both digits.
if (input(button2) == 0)
   increment = increment +1;
   vdezena = increment/10;
   vunit = increment - (vdezena*10);
   output_b(dezena[vdezena]);
   delay_ms(5);
   output_b(unit[vunit]);
   delay_ms(5);
thank you very much
nina
PostPosted: Sun May 16, 2010 9:13 pm     Reply with quote
The simple answer is to put a 500 ms delay statement at the start of
the if() block.
Ideally, you wouldn't check the switch with an if() statement, instead
you would use a debounce routine. See this thread:
http://www.ccsinfo.com/forum/viewtopic.php?t=42285&highlight=debounce+button
nina
increment
PostPosted: Mon May 17, 2010 9:52 am     Reply with quote
I tried put a delay after if but the 7 segment display responsible to show output_b(dezena[vdezena]) start flashing.
What can I do to solve this problem?
Thank you
Nina
PostPosted: Mon May 17, 2010 5:50 pm     Reply with quote
Use the pushbutton code shown in this post:
http://www.ccsinfo.com/forum/viewtopic.php?t=19874&start=1
Connect a push-button switch and a pull-up resistor to a pin on your PIC:
           +5v
            > 4.7K
            <         ___ Push button switch
To          |        _|_|_
PIC -----------------o   o------
pin                            |
                              --- GND
Then change your main program so it's similar to this:
int8 increment = 0;
   wait_for_keypress();
   increment++;
   // Put the 7-segment code here.
nina
increment
PostPosted: Wed May 19, 2010 5:00 pm     Reply with quote
Thank you for all responses...the way I solved the problem was:
while (input(button1) == 0)
delay_ms(5);
output_b(unidade[vunidade]);
delay_ms(5);
   a++;
   if (a == 50)
      incrementa = incrementa +1;
      vdezena = incrementa/10;
      vunidade = incrementa - (vdezena*10);
      delay_ms(5);
      delay_ms(5);
      a = 0;
It is working but I would like to know if there is another way to do this...
tks again
nina
nina
increment
PostPosted: Sat May 22, 2010 1:55 pm     Reply with quote
What is the way and/or hardware that I can use to "save" some pins at PIC when using 7 segments display?
Suppose I need use 6 display 7 segments. How to "save" pins at PIC?
Thank you
Nina
PostPosted: Sat May 22, 2010 2:04 pm     Reply with quote
I think you are asking how to multiplex the pins on one 7-segment display.
Normally, the multiplexing is done with several displays. 7 pins are used
on the PIC to display the segments. Then other pins on the PIC are
used to enable each display (each digit).
Scroll down to Figure 6 on this webpage. It shows how to connect the
wires.
http://www.melabs.com/resources/articles/ledart.htm
Is this what you really want to do ?
nina
multiplex
PostPosted: Sat May 22, 2010 3:41 pm     Reply with quote
That is what I am looking for...
Where can I find some examples (CCS) about multiplexing 7 segment display.
Thank you for this informations
