my question relates to the HOUR registers. In the datasheet bits 0-3 set the hour. Bits 4 and 5 each indicate an additional 10 hours. Bit 6 is the 12/ !24 hour setting.
All of the drivers I have seen on the web read the hours value using a straight BCD to binary conversion, meaning that if the time is (in 24hr format) 10pm == 22:00
then the register reads 00110010 == 0x32 == 50 decimal
then that converts from BCD to binary as an hour of 32 o'clock, which is clearly wrong. In the linked driver, this line reads the register:
dt->hours = bcd2bin(bcd_hrs & 0x3F);
and converts using:
char bcd2bin(char bcd_value) {
char temp;
char temp1;
temp = bcd_value;
// Shifting the upper digit right by 1 is
// the same as multiplying it by 8.
temp >>= 1;
// Isolate the bits for the upper digit.
temp &= 0x78;
