RTC bcd->binary in 24 hour modes
Oli
PostPosted: Tue May 04, 2010 10:18 am     Reply with quote
Hi All
I'm using the DS1337 - appears to work fine. I based my code loosely on the driver here:
http://www.ccsinfo.com/forum/viewtopic.php?t=28366&highlight=ds1337
my question relates to the HOUR registers. In the datasheet bits 0-3 set the hour. Bits 4 and 5 each indicate an additional 10 hours. Bit 6 is the 12/ !24 hour setting.
All of the drivers I have seen on the web read the hours value using a straight BCD to binary conversion, meaning that if the time is (in 24hr format) 10pm == 22:00
then the register reads 00110010 == 0x32 == 50 decimal
then that converts from BCD to binary as an hour of 32 o'clock, which is clearly wrong. In the linked driver, this line reads the register:
dt->hours   = bcd2bin(bcd_hrs  & 0x3F);
and converts using:
char bcd2bin(char bcd_value) {
   char temp;
   char temp1;
   temp = bcd_value;
   // Shifting the upper digit right by 1 is
   // the same as multiplying it by 8.
   temp >>= 1;
   // Isolate the bits for the upper digit.
   temp &= 0x78;
   // Now return: (Tens * 8) + (Tens * 2) + Ones
   (temp + (temp >> 2) + (bcd_value & 0x0f));
   return temp;
What am I missing? Are all of the drivers wrong?
Thanks in advance
FvM
PostPosted: Tue May 04, 2010 11:55 am     Reply with quote
You misunderstood the coding of hour tens. 22h is actually coded as 0x22, not 0x32. The tens field has
regular BCD encoding as all others, too.
