karthickiw
Need IC number for RS232 to RS485 |
Posted: Fri Mar 26, 2010 6:32 am |
Hi CCS Friends,
What type of IC use for RS232 to RS485 conversion to use RS485.c Inbuilt drivers. |
Posted: Fri Mar 26, 2010 6:57 am |
If you had taken the time to use the Forum Search to search on RS485 you would have found this:
http://www.ccsinfo.com/forum/viewtopic.php?t=40757
It includes a schematic showing one chip that can be used.
The 74174, 74175 and 74176 chips can also be used. _________________ Google and Forum Search are some of your best tools!!!! |
John P
Posted: Fri Mar 26, 2010 10:26 am |
And not wishing to sound repetitive, but:
When you say RS232, do you mean real genuine RS232 using +/- 12V signaling levels, or do you mean simply a serial port?
The requirements for conversion to RS485 would be totally different. |
