raffaele
Starting PIC18 and PIC24 |
Posted: Fri Feb 19, 2010 4:54 am |
Hello to all,
I'm starting using PIC18 and PIC24 family with PCWHD 4.093.
I have few PIC like 24HJ64GP502, 18F25J11, 24HJ128GP502. I wrote a simple code for blinking a led but it's not working.
Maybe I don't configure fuses in the right way.
Here the code:
Code: | #include <24hj64gp502.h>
#fuses FRC,NOWDT
#use delay(clock=7370000)
set_tris_b (0xf0);
output_low(PIN_B3);
delay_ms(200);
output_high(PIN_B3);
delay_ms(200);
Thank you for your help.
Raffaele |
logical
Joined: 21 Dec 2009 Posts: 57 Location: SouthPort, UK
Posted: Fri Feb 19, 2010 11:49 am |
A copy of my fuses that work with the internal oscillator, did a blink led program myself as just started on the GP502 and GP504's.
Code: | #include<24HJ128GP502.h>
#FUSES NOBSS //No boot segment
#FUSES FRC //Internal Fast RC Oscillator
#FUSES NOCKSFSM //Clock Switching is disabled, fail Safe clock monitor is disabled
#FUSES OSCIO //OSC2 is general purpose output
#FUSES NOPR //Pimary oscillaotr disabled
#FUSES NOWINDIS //Watch Dog Timer in Window mode
#FUSES WPRES128 //Watch Dog Timer PreScalar 1:128
#FUSES WPOSTS16 //Watch Dog Timer PostScalar 1:32768
#FUSES PUT128 //Power On Reset Timer value 128ms
#FUSES IOL1WAY //Allows only one reconfiguration of peripheral pins
#FUSES NORSS //No secure segment RAM
#FUSES NOSSS //No secure segment
#FUSES NOWRTSS //Secure segment not write protected
#FUSES NORBS //No Boot RAM defined
#FUSES NOCOE //Device will reset into operational mode
#FUSES NOJTAG //JTAG disabled
#FUSES ICSP3 //ICD uses PGC3/PGD3 pins
#FUSES NOALTI2C //I2C mapped to alternate pins
raffaele
Posted: Wed Feb 24, 2010 3:25 am |
Thank you, it works. I found also PIC24 Wizard is good to configure fuses. |
