Starting PIC18 and PIC24
raffaele
PostPosted: Fri Feb 19, 2010 4:54 am     Reply with quote
Hello to all,
I'm starting using PIC18 and PIC24 family with PCWHD 4.093.
I have few PIC like 24HJ64GP502, 18F25J11, 24HJ128GP502. I wrote a simple code for blinking a led but it's not working.
Maybe I don't configure fuses in the right way.
Here the code:
#include <24hj64gp502.h>
#fuses FRC,NOWDT
#use delay(clock=7370000)
set_tris_b (0xf0);
   output_low(PIN_B3);
   delay_ms(200);
   output_high(PIN_B3);
   delay_ms(200);
Thank you for your help.
Raffaele
logical
PostPosted: Fri Feb 19, 2010 11:49 am     Reply with quote
A copy of my fuses that work with the internal oscillator, did a blink led program myself as just started on the GP502 and GP504's.
#include<24HJ128GP502.h>
#FUSES NOWRTB                   //Boot block not write protected
#FUSES NOBSS                    //No boot segment
#FUSES FRC                      //Internal Fast RC Oscillator
#FUSES NOCKSFSM                 //Clock Switching is disabled, fail Safe clock monitor is disabled
#FUSES OSCIO                    //OSC2 is general purpose output
#FUSES NOPR                     //Pimary oscillaotr disabled
#FUSES NOWINDIS                 //Watch Dog Timer in Window mode
#FUSES WPRES128                 //Watch Dog Timer PreScalar 1:128
#FUSES WPOSTS16                 //Watch Dog Timer PostScalar 1:32768
#FUSES PUT128                   //Power On Reset Timer value 128ms
#FUSES IOL1WAY                  //Allows only one reconfiguration of peripheral pins
#FUSES NOIESO                   //Internal External Switch Over mode disabled
#FUSES NORSS                    //No secure segment RAM
#FUSES NOSSS                    //No secure segment
#FUSES NOWRTSS                  //Secure segment not write protected
#FUSES NORBS                    //No Boot RAM defined
#FUSES NOCOE                    //Device will reset into operational mode
#FUSES ICSP3                    //ICD uses PGC3/PGD3 pins
#FUSES NOALTI2C                 //I2C mapped to alternate pins
raffaele
PostPosted: Wed Feb 24, 2010 3:25 am     Reply with quote
Thank you, it works. I found also PIC24 Wizard is good to configure fuses.
