Crosslink Guest
Conversion of code |
Posted: Tue Feb 23, 2010 4:00 pm |
can someone help me in the conversion of this code. It was written for a sensor and a Controller: NEC V850/SG3 (uPD70F3740) with the Compiler : IAR compiler for V850 (3.50A).
I will like to compile it with CCS PIC C Compiler.
Main.c
// S E N S I R I O N AG, Laubisruetistr. 50, CH-8712 Staefa, Switzerland
// Project : SHT2x Sample Code (V1.1)
// File : main.c
// Author : MST
// Controller: NEC V850/SG3 (uPD70F3740)
// Compiler : IAR compiler for V850 (3.50A)
// Brief : This code is an example how to implement basic commands for the
// humidity and temperature sensor SHT2x.
// Due to compatibility reasons the I2C interface is implemented
// as "bit-banging" on normal I/O's. This code is written for an
// easy understanding and is neither optimized for speed nor code
// size.
// Porting to a different microcontroller (uC):
// - define the byte-order for your uC (e.g. little endian) in typedefs.h
// - definitions of basic types may have to be changed in typedefs.h
// - change the port functions / definitions for your uC in I2C_HAL.h/.c
// - adapt the timing of the delay function for your uC in system.c
// - adapt the HW_Init() in system.c
// - change the uC register definition file <io70f3740.h> in system.h
//---------- Includes ----------------------------------------------------------
#include "SHT2x.h" //header file for SHT2x functions
#include "I2C_HAL.h" //header file for I2C hardware abstraction
#include "DisplayDip204.h" //header file for display functions
#include "System.h" //header file for system settings
#include <stdio.h> //header file standard input / output functions
int main()
{ // variables
u8t error = 0; //variable for error code. For codes see system.h
u8t userRegister; //variable for user register
bt endOfBattery; //variable for end of battery
nt16 sRH; //variable for raw humidity ticks
ft humidityRH; //variable for relative humidity[%RH] as float
char humitityOutStr[21]; //output string for humidity value
nt16 sT; //variable for raw temperature ticks
ft temperatureC; //variable for temperature[°C] as float
char temperatureOutStr[21]; //output string for temperature value
u8t SerialNumber_SHT2x[8]; //64bit serial number
Init_HW(); //initializes Hardware (osc, watchdog,...)
I2c_Init(); //initializes uC-ports for I2C
DisplayInit(); //initializes LCD
DisplayEnableBacklight(); //enable LCD backlight
DisplayWriteString(0,0," SHT2x Sample Code "); //write project title on LCD
DelayMicroSeconds(15000); //wait for sensor initialization t_powerUp (15ms)
//note: The following code segments show how to use the different functions
// of SHT2x. The loop does not show a typical sequence in an application
{ error = 0; // reset error status
// --- Reset sensor by command ---
error |= SHT2x_SoftReset();
// --- Read the sensors serial number (64bit) ---
error |= SHT2x_GetSerialNumber(SerialNumber_SHT2x);
// --- Set Resolution e.g. RH 10bit, Temp 13bit ---
error |= SHT2x_ReadUserRegister(&userRegister); //get actual user reg
userRegister = (userRegister & ~SHT2x_RES_MASK) | SHT2x_RES_10_13BIT;
error |= SHT2x_WriteUserRegister(&userRegister); //write changed user reg
// --- measure humidity with "Hold Master Mode (HM)" ---
error |= SHT2x_MeasureHM(HUMIDITY, &sRH);
// --- measure temperature with "Polling Mode" (no hold master) ---
error |= SHT2x_MeasurePoll(TEMP, &sT);
//-- calculate humidity and temperature --
temperatureC = SHT2x_CalcTemperatureC(sT.u16);
humidityRH = SHT2x_CalcRH(sT.u16, sRH.u16);
// --- check end of battery status (eob)---
// note: a RH / Temp. measurement must be executed to update the status of eob
if( (userRegister & SHT2x_EOB_MASK) == SHT2x_EOB_ON ) endOfBattery = true;
else endOfBattery = false;
//-- write humidity and temperature values on LCD --
sprintf(humitityOutStr, "Humidity RH:%6.2f %% ",humidityRH);
sprintf(temperatureOutStr, "Temperature:%6.2f€C",temperatureC);
DisplayWriteString(2,0,humitityOutStr);
DisplayWriteString(3,0,temperatureOutStr);
//-- write error or low batt status un LCD --
if(error != 0)
{ DisplayWriteString(1,3,"Error occurred");
DisplayWriteString(2,0,"Humidity RH: --.-- %%");
DisplayWriteString(3,0,"Temperature: --.--€C");
else if(endOfBattery) DisplayWriteString(1,3,"Low Batt");
else DisplayWriteString(1,0," ");
DelayMicroSeconds(300000); // wait 0.3s for next measurement
I2C_HAL.c code
// File : I2C_HAL.c
// Author : MST
// Brief : I2C Hardware abstraction layer
void I2c_Init ()
SDA=LOW; // Set port as output for
configuration
SCL=LOW; // Set port as output for
configuration
SDA_CONF=LOW; // Set SDA level as low for
output mode
SCL_CONF=LOW; // Set SCL level as low for
output mode
SDA=HIGH; // I2C-bus idle mode SDA
released (input)
SCL=HIGH; // I2C-bus idle mode SCL
released (input)
void I2c_StartCondition ()
SDA=HIGH;
SCL=HIGH;
SDA=LOW;
DelayMicroSeconds(10); // hold time start condition
(t_HD;STA)
SCL=LOW;
void I2c_StopCondition ()
SDA=LOW;
SCL=LOW;
SCL=HIGH;
DelayMicroSeconds(10); // set-up time stop condition
(t_SU;STO)
SDA=HIGH;
u8t I2c_WriteByte (u8t txByte)
u8t mask,error=0;
for (mask=0x80; mask>0; mask>>=1) //shift bit for
masking (8 times)
{ if ((mask & txByte) == 0) SDA=LOW;//masking txByte,
write bit to SDA-Line
else SDA=HIGH;
DelayMicroSeconds(1); //data set-up
time (t_SU;DAT)
SCL=HIGH; //generate clock
pulse on SCL
DelayMicroSeconds(5); //SCL high time
(t_HIGH)
SCL=LOW;
DelayMicroSeconds(1); //data hold time
(t_HD;DAT)
SDA=HIGH; //release SDA-
line
SCL=HIGH; //clk #9 for ack
time (t_SU;DAT)
if(SDA_CONF==HIGH) error=ACK_ERROR; //check ack from
i2c slave
SCL=LOW;
DelayMicroSeconds(20); //wait time to
see byte package on scope
return error; //return error
code
u8t I2c_ReadByte (etI2cAck ack)
u8t mask,rxByte=0;
line
masking (8 times)
{ SCL=HIGH; //start clock on
SCL-line
time (t_SU;DAT)
DelayMicroSeconds(3); //SCL high time
(t_HIGH)
if (SDA_CONF==1) rxByte=(rxByte | mask); //read bit
SCL=LOW;
(t_HD;DAT)
SDA=ack; //send
acknowledge if necessary
time (t_SU;DAT)
(t_HIGH)
SCL=LOW;
line
return rxByte; //return error
code
I2C_HAL.h code
Code: | #ifndef I2C_HAL_H
#define I2C_HAL_H
// File : I2C_HAL.h
// Author : MST
#include "system.h"
//---------- Defines -----------------------------------------------------------
//I2C ports
//The communication on SDA and SCL is done by switching pad direction
//For a low level on SCL or SDA, direction is set to output. For a high level on
//SCL or SDA, direction is set to input. (pull up resistor active)
#define SDA PM3H_bit.no0 //SDA on I/O P38 defines direction (input=1/output=0)
#define SDA_CONF P3H_bit.no0 //SDA level on output direction
#define SCL PM3H_bit.no1 //SCL on I/O P39 defines direction (input=1/output=0)
#define SCL_CONF P3H_bit.no1 //SCL level on output direction
//---------- Enumerations ------------------------------------------------------
// I2C level
typedef enum{
LOW = 0,
HIGH = 1,
}etI2cLevel;
// I2C acknowledge
typedef enum{
ACK = 0,
NO_ACK = 1,
}etI2cAck;
void I2c_Init ();
//Initializes the ports for I2C interface
void I2c_StartCondition ();
// writes a start condition on I2C-bus
// input : -
// output: -
// return: -
// note : timing (delay) may have to be changed for different microcontroller
// _____
// SDA: |_____
// _______
// SCL : |___
void I2c_StopCondition ();
// writes a stop condition on I2C-bus
// input : -
// output: -
// return: -
// _____
// SDA: _____|
// _______
// SCL : ___|
u8t I2c_WriteByte (u8t txByte);
// writes a byte to I2C-bus and checks acknowledge
// input: txByte transmit byte
// output: -
// return: error
// note: timing (delay) may have to be changed for different microcontroller
u8t I2c_ReadByte (etI2cAck ack);
// reads a byte on I2C-bus
// input: rxByte receive byte
// output: rxByte
#endif |
SHT21.c code
Code: | //==============================================================================
// File : SHT2x.c
// Author : MST
// Brief : Sensor layer. Functions for sensor access
#include "SHT2x.h"
u8t SHT2x_CheckCrc(u8t data[], u8t nbrOfBytes, u8t checksum)
u8t crc = 0;
u8t byteCtr;
//calculates 8-Bit checksum with given polynomial
for (byteCtr = 0; byteCtr < nbrOfBytes; ++byteCtr)
{ crc ^= (data[byteCtr]);
for (u8t bit = 8; bit > 0; --bit)
{ if (crc & 0x80) crc = (crc << 1) ^ POLYNOMIAL;
else crc = (crc << 1);
if (crc != checksum) return CHECKSUM_ERROR;
else return 0;
u8t SHT2x_ReadUserRegister(u8t *pRegisterValue)
u8t checksum; //variable for checksum byte
u8t error=0; //variable for error code
I2c_StartCondition();
error |= I2c_WriteByte (I2C_ADR_W);
error |= I2c_WriteByte (USER_REG_R);
error |= I2c_WriteByte (I2C_ADR_R);
*pRegisterValue = I2c_ReadByte(ACK);
checksum=I2c_ReadByte(NO_ACK);
error |= SHT2x_CheckCrc (pRegisterValue,1,checksum);
I2c_StopCondition();
return error;
u8t SHT2x_WriteUserRegister(u8t *pRegisterValue)
error |= I2c_WriteByte (USER_REG_W);
error |= I2c_WriteByte (*pRegisterValue);
return error;
u8t SHT2x_MeasureHM(etSHT2xMeasureType eSHT2xMeasureType, nt16 *pMeasurand)
u8t checksum; //checksum
u8t data[2]; //data array for checksum verification
u8t error=0; //error variable
u16t i; //counting variable
//-- write I2C sensor address and command --
error |= I2c_WriteByte (I2C_ADR_W); // I2C Adr
switch(eSHT2xMeasureType)
{ case HUMIDITY: error |= I2c_WriteByte (TRIG_RH_MEASUREMENT_HM); break;
case TEMP : error |= I2c_WriteByte (TRIG_T_MEASUREMENT_HM); break;
default: assert(0);
//-- wait until hold master is released --
SCL=HIGH; // set SCL I/O port as input
for(i=0; i<1000; i++) // wait until master hold is released or
{ DelayMicroSeconds(1000); // a timeout (~1s) is reached
if (SCL_CONF==1) break;
//-- check for timeout --
if(SCL_CONF==0) error |= TIME_OUT_ERROR;
//-- read two data bytes and one checksum byte --
pMeasurand->s16.u8H = data[0] = I2c_ReadByte(ACK);
pMeasurand->s16.u8L = data[1] = I2c_ReadByte(ACK);
//-- verify checksum --
error |= SHT2x_CheckCrc (data,2,checksum);
return error;
u8t SHT2x_MeasurePoll(etSHT2xMeasureType eSHT2xMeasureType, nt16 *pMeasurand)
u16t i=0; //counting variable
{ case HUMIDITY: error |= I2c_WriteByte (TRIG_RH_MEASUREMENT_POLL); break;
case TEMP : error |= I2c_WriteByte (TRIG_T_MEASUREMENT_POLL); break;
default: assert(0);
//-- poll every 10ms for measurement ready. Timeout after 20 retries (200ms)--
do
{ I2c_StartCondition();
DelayMicroSeconds(10000); //delay 10ms
if(i++ >= 20) break;
} while(I2c_WriteByte (I2C_ADR_R) == ACK_ERROR);
if (i>=20) error |= TIME_OUT_ERROR;
return error;
u8t SHT2x_SoftReset()
error |= I2c_WriteByte (SOFT_RESET); // Command
DelayMicroSeconds(15000); // wait till sensor has restarted
return error;
float SHT2x_CalcRH(u16t u16sT, u16t u16sRH)
ft sT = (ft) u16sT; // convert sT to float
ft sRH = (ft) u16sRH; // convert sRH to float
ft humidityRH; // variable for result
//-- calculate relative humidity [%RH] --
humidityRH = c00 + c10*sRH + c01*sT + c20*sRH*sRH + c11*sRH*sT;
return humidityRH;
float SHT2x_CalcTemperatureC(u16t u16sT)
ft temperatureC; // variable for result
//-- calculate temperature [°C] --
temperatureC= c0 + c1*sT + c2*sT*sT ;
return temperatureC;
u8t SHT2x_GetSerialNumber(u8t u8SerialNumber[])
//Read from memory location 1
error |= I2c_WriteByte (I2C_ADR_W); //I2C address
error |= I2c_WriteByte (0xFA); //Command for readout on-chip memory
error |= I2c_WriteByte (0x0F); //on-chip memory address
error |= I2c_WriteByte (I2C_ADR_R); //I2C address
u8SerialNumber[5] = I2c_ReadByte(ACK); //Read SNB_3
I2c_ReadByte(ACK); //Read CRC SNB_3 (CRC is not analyzed)
u8SerialNumber[4] = I2c_ReadByte(ACK); //Read SNB_2
I2c_ReadByte(ACK); //Read CRC SNB_2 (CRC is not analyzed)
u8SerialNumber[3] = I2c_ReadByte(ACK); //Read SNB_1
I2c_ReadByte(ACK); //Read CRC SNB_1 (CRC is not analyzed)
u8SerialNumber[2] = I2c_ReadByte(ACK); //Read SNB_0
I2c_ReadByte(NO_ACK); //Read CRC SNB_0 (CRC is not analyzed)
//Read from memory location 2
error |= I2c_WriteByte (0xFC); //Command for readout on-chip memory
error |= I2c_WriteByte (0xC9); //on-chip memory address
u8SerialNumber[1] = I2c_ReadByte(ACK); //Read SNC_1
u8SerialNumber[0] = I2c_ReadByte(ACK); //Read SNC_0
I2c_ReadByte(ACK); //Read CRC SNC0/1 (CRC is not analyzed)
u8SerialNumber[7] = I2c_ReadByte(ACK); //Read SNA_1
u8SerialNumber[6] = I2c_ReadByte(ACK); //Read SNA_0
I2c_ReadByte(NO_ACK); //Read CRC SNA0/1 (CRC is not analyzed)
return error;
SHT21.h code
Code: | #ifndef SHT2x_H
#define SHT2x_H
// File : SHT2x.h
// Author : MST
// Brief : Sensor layer. Definitions of commands and registers,
// functions for sensor access
#include "system.h"
// CRC
const u16t POLYNOMIAL = 0x131; //P(x)=x^8+x^5+x^4+1 = 100110001
//coefficients relative humidity conversion for SHT2x (preproduction prototype sample)
//coefficients are scaled for 16 bit values
const ft c00=-7.7239;
const ft c10= 3.8219E-2/16;
const ft c01= 2.5329E-4/4;
const ft c20=-3.6634E-6/256;
const ft c11= 8.6345E-7/64;
//coefficients temperature conversion for SHT2x (preproduction prototype sample)
const ft c0 =-46.8375;
const ft c1 = 1.1072E-2/4;
const ft c2 =-2.1233E-8/16;
// sensor command
typedef enum{
TRIG_T_MEASUREMENT_HM = 0xE3, // command trig. temp meas. hold master
TRIG_RH_MEASUREMENT_HM = 0xE5, // command trig. humidity meas. hold master
TRIG_T_MEASUREMENT_POLL = 0xF3, // command trig. temp meas. no hold master
TRIG_RH_MEASUREMENT_POLL = 0xF5, // command trig. humidity meas. no hold master
USER_REG_W = 0xE6, // command writing user register
USER_REG_R = 0xE7, // command reading user register
SOFT_RESET = 0xFE // command soft reset
}etSHT2xCommand;
typedef enum {
SHT2x_RES_12_14BIT = 0x00, // RH=12bit, T=14bit
SHT2x_RES_8_12BIT = 0x01, // RH= 8bit, T=12bit
SHT2x_RES_10_13BIT = 0x80, // RH=10bit, T=13bit
SHT2x_RES_11_11BIT = 0x81, // RH=11bit, T=11bit
SHT2x_RES_MASK = 0x81 // Mask for res. bits (7,0) in user reg.
} etSHT2xResolution;
typedef enum {
SHT2x_EOB_ON = 0x40, // end of battery
SHT2x_EOB_MASK = 0x40, // Mask for EOB bit(6) in user reg.
} etSHT2xEob;
typedef enum {
SHT2x_HEATER_ON = 0x04, // heater on
SHT2x_HEATER_OFF = 0x00, // heater off
SHT2x_HEATER_MASK = 0x04, // Mask for Heater bit(2) in user reg.
} etSHT2xHeater;
// measurement signal selection
typedef enum{
HUMIDITY,
TEMP
}etSHT2xMeasureType;
typedef enum{
I2C_ADR_W = 128, // sensor I2C address + write bit
I2C_ADR_R = 129 // sensor I2C address + read bit
}etI2cHeader;
u8t SHT2x_CheckCrc(u8t data[], u8t nbrOfBytes, u8t checksum);
// calculates checksum for n bytes of data and compares it with expected
// checksum
// input: data[] checksum is built based on this data
// nbrOfBytes checksum is built for n bytes of data
// checksum expected checksum
// return: error: CHECKSUM_ERROR = checksum does not match
// 0 = checksum matches
u8t SHT2x_ReadUserRegister(u8t *pRegisterValue);
// reads the SHT2x user register (8bit)
// input : -
// output: *pRegisterValue
// return: error
u8t SHT2x_WriteUserRegister(u8t *pRegisterValue);
// writes the SHT2x user register (8bit)
// input : *pRegisterValue
// output: -
// return: error
u8t SHT2x_MeasurePoll(etSHT2xMeasureType eSHT2xMeasureType, nt16 *pMeasurand);
// measures humidity or temperature. This function polls every 10ms until
// measurement is ready.
// input: eSHT2xMeasureType
// output: *pMeasurand: humidity / temperature as raw value
// return: error
// note: timing for timeout may be changed
u8t SHT2x_MeasureHM(etSHT2xMeasureType eSHT2xMeasureType, nt16 *pMeasurand);
// measures humidity or temperature. This function waits for a hold master until
// measurement is ready or a timeout occurred.
// return: error
u8t SHT2x_SoftReset();
// performs a reset
// input: -
// output: -
// return: error
float SHT2x_CalcRH(u16t u16sT, u16t u16sRH);
// calculates the relative humidity
// input: sT: temperature raw value (16bit scaled)
// sRH: humidity raw value (16bit scaled)
// return: pHumidity relative humidity [%RH]
float SHT2x_CalcTemperatureC(u16t u16sT);
// calculates temperature
// return: temperature [°C]
u8t SHT2x_GetSerialNumber(u8t u8SerialNumber[]);
// gets serial number of SHT2x according application note "How To
// Read-Out the Serial Number"
// note: readout of this function is not CRC checked
// input: -
// output: u8SerialNumber: Array of 8 bytes (64Bits)
// MSB LSB
// u8SerialNumber[7] u8SerialNumber[0]
// SNA_1 SNA_0 SNB_3 SNB_2 SNB_1 SNB_0 SNC_1 SNC_0
// return: error
#endif |
system.c code
// File : System.c
// Author : MST
// Brief : System functions
#include "system.h"
void Init_HW (void)
//-- initialize system clock of V850 (fcpu = fosc, no PLL) --
PRCMD = 0x00; // unlock PCC register
PCC = 0x00; // perform settings in PCC register
RCM = 0x01; // disable ring oscillator
//-- watchdog --
WDTM2 = 0x0f; // stop watchdog
//-- interrupts --
__EI(); // enable interrupts for debugging with minicube
//Settings for debugging with Sensirion EKH4 and minicube2, power up sensor
//Not needed for normal use
PMDLL = 0xF0;
PDLL = 0x04;
#pragma optimize = s none
void DelayMicroSeconds (u32t nbrOfUs)
for(u32t i=0; i<nbrOfUs; i++)
{ //__asm("nop"); //nop's may be added for timing adjustment
SHT21.H CODE
Code: | #ifndef SYSTEM_H
#define SYSTEM_H
// File : System.h
// Author : MST
// Brief : System functions, global definitions
#include "io70f3740.h" // controller register definitions
#include <assert.h> // assert functions
#include <intrinsics.h> // low level microcontroller commands
#include "typedefs.h" // type definitions
// Error codes
typedef enum{
ACK_ERROR = 0x01,
TIME_OUT_ERROR = 0x02,
CHECKSUM_ERROR = 0x04,
UNIT_ERROR = 0x08
}etError;
void Init_HW (void);
// Initializes the used hardware
void DelayMicroSeconds (u32t nbrOfUs);
// wait function for small delays
// input: nbrOfUs wait x times approx. one micro second (fcpu = 4MHz)
// return: -
// note: smallest delay is approx. 30us due to function call
#endif |
TYPEDEFS.C CODE
Code: | #ifndef TYPEDEFS_H
#define TYPEDEFS_H
// File : typedefs.h
// Author : MST
// Brief : Definitions of typedefs for good readability and portability
//Processor endian system
//#define BIG ENDIAN //e.g. Motorola (not tested at this time)
#define LITTLE_ENDIAN //e.g. PIC, 8051, NEC V850
// basic types: making the size of types clear
typedef unsigned char u8t; ///< range: 0 .. 255
typedef signed char i8t; ///< range: -128 .. +127
typedef unsigned short u16t; ///< range: 0 .. 65535
typedef signed short i16t; ///< range: -32768 .. +32767
typedef unsigned long u32t; ///< range: 0 .. 4'294'967'295
typedef signed long i32t; ///< range: -2'147'483'648 .. +2'147'483'647
typedef float ft; ///< range: +-1.18E-38 .. +-3.39E+38
typedef double dt; ///< range: .. +-1.79E+308
typedef bool bt; ///< values: 0, 1 (real bool used)
typedef union {
u16t u16; // element specifier for accessing whole u16
i16t i16; // element specifier for accessing whole i16
struct {
#ifdef LITTLE_ENDIAN // Byte-order is little endian
u8t u8L; // element specifier for accessing low u8
u8t u8H; // element specifier for accessing high u8
#else // Byte-order is big endian
u8t u8H; // element specifier for accessing low u8
u8t u8L; // element specifier for accessing high u8
#endif
} s16; // element spec. for acc. struct with low or high u8
} nt16;
typedef union {
u32t u32; // element specifier for accessing whole u32
i32t i32; // element specifier for accessing whole i32
struct {
u16t u16L; // element specifier for accessing low u16
u16t u16H; // element specifier for accessing high u16
u16t u16H; // element specifier for accessing low u16
u16t u16L; // element specifier for accessing high u16
#endif
} s32; // element spec. for acc. struct with low or high u16
} nt32;
#endif |
The code for the display is not too necesary. I am interfacing it with a PC through serial COM port, using max233.
Thanks |
Crosslink Guest
PIC to be used |
Posted: Tue Feb 23, 2010 4:36 pm |
I omitted the PIC I intend to use with the driver. I would like to use PIC18F series. Any of them will do, say PIC18F4550. Thanks |
