Conversion of code
Crosslink
Conversion of code
PostPosted: Tue Feb 23, 2010 4:00 pm     Reply with quote
can someone help me in the conversion of this code. It was written for a sensor and a Controller: NEC V850/SG3 (uPD70F3740) with the Compiler : IAR compiler for V850 (3.50A).
I will like to compile it with CCS PIC C Compiler.
Main.c
//    S E N S I R I O N   AG,  Laubisruetistr. 50, CH-8712 Staefa, Switzerland
// Project   :  SHT2x Sample Code (V1.1)
// File      :  main.c
// Author    :  MST
// Controller:  NEC V850/SG3 (uPD70F3740)
// Compiler  :  IAR compiler for V850 (3.50A)
// Brief     :  This code is an example how to implement basic commands for the
//              humidity and temperature sensor SHT2x.
//              Due to compatibility reasons the I2C interface is implemented
//              as "bit-banging" on normal I/O's. This code is written for an
//              easy understanding and is neither optimized for speed nor code
//              size.
// Porting to a different microcontroller (uC):
//   - define the byte-order for your uC (e.g. little endian) in typedefs.h
//   - definitions of basic types may have to be changed  in typedefs.h
//   - change the port functions / definitions for your uC    in I2C_HAL.h/.c
//   - adapt the timing of the delay function for your uC     in system.c
//   - adapt the HW_Init()                                    in system.c
//   - change the uC register definition file <io70f3740.h>   in system.h
//---------- Includes ----------------------------------------------------------
#include "SHT2x.h"          //header file for SHT2x functions
#include "I2C_HAL.h"        //header file for I2C hardware abstraction
#include "DisplayDip204.h"  //header file for display functions
#include "System.h"         //header file for system settings
#include <stdio.h>          //header file standard input / output functions
int main()
{  // variables
  u8t  error = 0;              //variable for error code. For codes see system.h
  u8t  userRegister;           //variable for user register
  bt   endOfBattery;           //variable for end of battery
  nt16 sRH;                    //variable for raw humidity ticks
  ft   humidityRH;             //variable for relative humidity[%RH] as float
  char humitityOutStr[21];     //output string for humidity value
  nt16 sT;                     //variable for raw temperature ticks
  ft   temperatureC;           //variable for temperature[°C] as float
  char temperatureOutStr[21];  //output string for temperature value
  u8t  SerialNumber_SHT2x[8];  //64bit serial number
  Init_HW();                   //initializes Hardware (osc, watchdog,...)
  I2c_Init();                  //initializes uC-ports for I2C
  DisplayInit();               //initializes LCD
  DisplayEnableBacklight();    //enable LCD backlight
  DisplayWriteString(0,0," SHT2x Sample Code "); //write project title on LCD
  DelayMicroSeconds(15000);    //wait for sensor initialization t_powerUp (15ms)
  //note: The following code segments show how to use the different functions
  //      of SHT2x. The loop does not show a typical sequence in an application
  { error = 0;                                       // reset error status
    // --- Reset sensor by command ---
    error |= SHT2x_SoftReset();
    // --- Read the sensors serial number (64bit) ---
    error |= SHT2x_GetSerialNumber(SerialNumber_SHT2x);
    // --- Set Resolution e.g. RH 10bit, Temp 13bit ---
    error |= SHT2x_ReadUserRegister(&userRegister);  //get actual user reg
    userRegister = (userRegister & ~SHT2x_RES_MASK) | SHT2x_RES_10_13BIT;
    error |= SHT2x_WriteUserRegister(&userRegister); //write changed user reg
    // --- measure humidity with "Hold Master Mode (HM)"  ---
    error |= SHT2x_MeasureHM(HUMIDITY, &sRH);
    // --- measure temperature with "Polling Mode" (no hold master) ---
    error |= SHT2x_MeasurePoll(TEMP, &sT);
    //-- calculate humidity and temperature --
    temperatureC = SHT2x_CalcTemperatureC(sT.u16);
    humidityRH   = SHT2x_CalcRH(sT.u16, sRH.u16);
    // --- check end of battery status (eob)---
    // note: a RH / Temp. measurement must be executed to update the status of eob
    if( (userRegister & SHT2x_EOB_MASK) == SHT2x_EOB_ON ) endOfBattery = true;
    else endOfBattery = false;
    //-- write humidity and temperature values on LCD --
    sprintf(humitityOutStr,    "Humidity RH:%6.2f %% ",humidityRH);
    sprintf(temperatureOutStr, "Temperature:%6.2f€C",temperatureC);
    DisplayWriteString(2,0,humitityOutStr);
    DisplayWriteString(3,0,temperatureOutStr);
    //-- write error or low batt status un LCD --
    if(error != 0)
    { DisplayWriteString(1,3,"Error occurred");
      DisplayWriteString(2,0,"Humidity RH: --.-- %%");
      DisplayWriteString(3,0,"Temperature: --.--€C");
    else if(endOfBattery) DisplayWriteString(1,3,"Low Batt");
    else DisplayWriteString(1,0,"                    ");
    DelayMicroSeconds(300000);     // wait 0.3s for next measurement
I2C_HAL.c code
// File      :  I2C_HAL.c
// Author    :  MST
// Brief     :  I2C Hardware abstraction layer
void I2c_Init ()
  SDA=LOW;                // Set port as output for
configuration
  SCL=LOW;                // Set port as output for
configuration
  SDA_CONF=LOW;           // Set SDA level as low for
output mode
  SCL_CONF=LOW;           // Set SCL level as low for
output mode
  SDA=HIGH;               // I2C-bus idle mode SDA
released (input)
  SCL=HIGH;               // I2C-bus idle mode SCL
released (input)
void I2c_StartCondition ()
  SDA=HIGH;
  SCL=HIGH;
  SDA=LOW;
  DelayMicroSeconds(10);  // hold time start condition
(t_HD;STA)
  SCL=LOW;
void I2c_StopCondition ()
  SDA=LOW;
  SCL=LOW;
  SCL=HIGH;
  DelayMicroSeconds(10);  // set-up time stop condition
(t_SU;STO)
  SDA=HIGH;
u8t I2c_WriteByte (u8t txByte)
  u8t mask,error=0;
  for (mask=0x80; mask>0; mask>>=1)   //shift bit for
masking (8 times)
  { if ((mask & txByte) == 0) SDA=LOW;//masking txByte,
write bit to SDA-Line
    else SDA=HIGH;
    DelayMicroSeconds(1);             //data set-up
time (t_SU;DAT)
    SCL=HIGH;                         //generate clock
pulse on SCL
    DelayMicroSeconds(5);             //SCL high time
(t_HIGH)
    SCL=LOW;
    DelayMicroSeconds(1);             //data hold time
(t_HD;DAT)
  SDA=HIGH;                           //release SDA-
line
  SCL=HIGH;                           //clk #9 for ack
time (t_SU;DAT)
  if(SDA_CONF==HIGH) error=ACK_ERROR; //check ack from
i2c slave
  SCL=LOW;
  DelayMicroSeconds(20);              //wait time to
see byte package on scope
  return error;                       //return error
code
u8t I2c_ReadByte (etI2cAck ack)
  u8t mask,rxByte=0;
line
masking (8 times)
  { SCL=HIGH;                         //start clock on
SCL-line
time (t_SU;DAT)
    DelayMicroSeconds(3);             //SCL high time
(t_HIGH)
    if (SDA_CONF==1) rxByte=(rxByte | mask); //read bit
    SCL=LOW;
(t_HD;DAT)
  SDA=ack;                            //send
acknowledge if necessary
time (t_SU;DAT)
(t_HIGH)
  SCL=LOW;
line
  return rxByte;                      //return error
code
I2C_HAL.h code
#ifndef I2C_HAL_H
#define I2C_HAL_H
// File      :  I2C_HAL.h
// Author    :  MST
#include "system.h"
//---------- Defines -----------------------------------------------------------
//I2C ports
//The communication on SDA and SCL is done by switching pad direction
//For a low level on SCL or SDA, direction is set to output. For a high level on
//SCL or SDA, direction is set to input. (pull up resistor active)
#define SDA      PM3H_bit.no0 //SDA on I/O P38 defines direction (input=1/output=0)
#define SDA_CONF P3H_bit.no0  //SDA level on output direction
#define SCL      PM3H_bit.no1 //SCL on I/O P39 defines direction (input=1/output=0)
#define SCL_CONF P3H_bit.no1  //SCL level on output direction
//---------- Enumerations ------------------------------------------------------
//  I2C level
typedef enum{
  LOW                      = 0,
  HIGH                     = 1,
}etI2cLevel;
// I2C acknowledge
typedef enum{
  ACK                      = 0,
  NO_ACK                   = 1,
}etI2cAck;
void I2c_Init ();
//Initializes the ports for I2C interface
void I2c_StartCondition ();
// writes a start condition on I2C-bus
// input : -
// output: -
// return: -
// note  : timing (delay) may have to be changed for different microcontroller
//       _____
// SDA:       |_____
//       _______
// SCL :        |___
void I2c_StopCondition ();
// writes a stop condition on I2C-bus
// input : -
// output: -
// return: -
//              _____
// SDA:   _____|
//            _______
// SCL :  ___|
u8t I2c_WriteByte (u8t txByte);
// writes a byte to I2C-bus and checks acknowledge
// input:  txByte  transmit byte
// output: -
// return: error
// note: timing (delay) may have to be changed for different microcontroller
u8t I2c_ReadByte (etI2cAck ack);
// reads a byte on I2C-bus
// input:  rxByte  receive byte
// output: rxByte
SHT21.c code
// File      :  SHT2x.c
// Author    :  MST
// Brief     :  Sensor layer. Functions for sensor access
#include "SHT2x.h"
u8t SHT2x_CheckCrc(u8t data[], u8t nbrOfBytes, u8t checksum)
  u8t crc = 0;
  u8t byteCtr;
  //calculates 8-Bit checksum with given polynomial
  for (byteCtr = 0; byteCtr < nbrOfBytes; ++byteCtr)
  { crc ^= (data[byteCtr]);
    for (u8t bit = 8; bit > 0; --bit)
    { if (crc & 0x80) crc = (crc << 1) ^ POLYNOMIAL;
      else crc = (crc << 1);
  if (crc != checksum) return CHECKSUM_ERROR;
  else return 0;
u8t SHT2x_ReadUserRegister(u8t *pRegisterValue)
  u8t checksum;   //variable for checksum byte
  u8t error=0;    //variable for error code
  I2c_StartCondition();
  error |= I2c_WriteByte (I2C_ADR_W);
  error |= I2c_WriteByte (USER_REG_R);
  error |= I2c_WriteByte (I2C_ADR_R);
  *pRegisterValue = I2c_ReadByte(ACK);
  checksum=I2c_ReadByte(NO_ACK);
  error |= SHT2x_CheckCrc (pRegisterValue,1,checksum);
  I2c_StopCondition();
  return error;
u8t SHT2x_WriteUserRegister(u8t *pRegisterValue)
  error |= I2c_WriteByte (USER_REG_W);
  error |= I2c_WriteByte (*pRegisterValue);
  return error;
u8t SHT2x_MeasureHM(etSHT2xMeasureType eSHT2xMeasureType, nt16 *pMeasurand)
  u8t  checksum;   //checksum
  u8t  data[2];    //data array for checksum verification
  u8t  error=0;    //error variable
  u16t i;          //counting variable
  //-- write I2C sensor address and command --
  error |= I2c_WriteByte (I2C_ADR_W); // I2C Adr
  switch(eSHT2xMeasureType)
  { case HUMIDITY: error |= I2c_WriteByte (TRIG_RH_MEASUREMENT_HM); break;
    case TEMP    : error |= I2c_WriteByte (TRIG_T_MEASUREMENT_HM);  break;
    default: assert(0);
  //-- wait until hold master is released --
  SCL=HIGH;                     // set SCL I/O port as input
  for(i=0; i<1000; i++)         // wait until master hold is released or
  { DelayMicroSeconds(1000);    // a timeout (~1s) is reached
    if (SCL_CONF==1) break;
  //-- check for timeout --
  if(SCL_CONF==0) error |= TIME_OUT_ERROR;
  //-- read two data bytes and one checksum byte --
  pMeasurand->s16.u8H = data[0] = I2c_ReadByte(ACK);
  pMeasurand->s16.u8L = data[1] = I2c_ReadByte(ACK);
  //-- verify checksum --
  error |= SHT2x_CheckCrc (data,2,checksum);
  return error;
u8t SHT2x_MeasurePoll(etSHT2xMeasureType eSHT2xMeasureType, nt16 *pMeasurand)
  u16t i=0;        //counting variable
  { case HUMIDITY: error |= I2c_WriteByte (TRIG_RH_MEASUREMENT_POLL); break;
    case TEMP    : error |= I2c_WriteByte (TRIG_T_MEASUREMENT_POLL);  break;
    default: assert(0);
  //-- poll every 10ms for measurement ready. Timeout after 20 retries (200ms)--
  do
  { I2c_StartCondition();
    DelayMicroSeconds(10000);  //delay 10ms
    if(i++ >= 20) break;
  } while(I2c_WriteByte (I2C_ADR_R) == ACK_ERROR);
  if (i>=20) error |= TIME_OUT_ERROR;
  return error;
u8t SHT2x_SoftReset()
  error |= I2c_WriteByte (SOFT_RESET);                            // Command
  DelayMicroSeconds(15000); // wait till sensor has restarted
  return error;
float SHT2x_CalcRH(u16t u16sT, u16t u16sRH)
  ft sT  = (ft) u16sT;        // convert sT to float
  ft sRH = (ft) u16sRH;       // convert sRH to float
  ft humidityRH;              // variable for result
  //-- calculate relative humidity [%RH] --
  humidityRH = c00 + c10*sRH + c01*sT + c20*sRH*sRH + c11*sRH*sT;
  return humidityRH;
float SHT2x_CalcTemperatureC(u16t u16sT)
  ft temperatureC;            // variable for result
  //-- calculate temperature [°C] --
  temperatureC= c0 + c1*sT + c2*sT*sT ;
  return temperatureC;
u8t SHT2x_GetSerialNumber(u8t u8SerialNumber[])
  //Read from memory location 1
  error |= I2c_WriteByte (I2C_ADR_W);    //I2C address
  error |= I2c_WriteByte (0xFA);         //Command for readout on-chip memory
  error |= I2c_WriteByte (0x0F);         //on-chip memory address
  error |= I2c_WriteByte (I2C_ADR_R);    //I2C address
  u8SerialNumber[5] = I2c_ReadByte(ACK); //Read SNB_3
  I2c_ReadByte(ACK);                     //Read CRC SNB_3 (CRC is not analyzed)
  u8SerialNumber[4] = I2c_ReadByte(ACK); //Read SNB_2
  I2c_ReadByte(ACK);                     //Read CRC SNB_2 (CRC is not analyzed)
  u8SerialNumber[3] = I2c_ReadByte(ACK); //Read SNB_1
  I2c_ReadByte(ACK);                     //Read CRC SNB_1 (CRC is not analyzed)
  u8SerialNumber[2] = I2c_ReadByte(ACK); //Read SNB_0
  I2c_ReadByte(NO_ACK);                  //Read CRC SNB_0 (CRC is not analyzed)
  //Read from memory location 2
  error |= I2c_WriteByte (0xFC);         //Command for readout on-chip memory
  error |= I2c_WriteByte (0xC9);         //on-chip memory address
  u8SerialNumber[1] = I2c_ReadByte(ACK); //Read SNC_1
  u8SerialNumber[0] = I2c_ReadByte(ACK); //Read SNC_0
  I2c_ReadByte(ACK);                     //Read CRC SNC0/1 (CRC is not analyzed)
  u8SerialNumber[7] = I2c_ReadByte(ACK); //Read SNA_1
  u8SerialNumber[6] = I2c_ReadByte(ACK); //Read SNA_0
  I2c_ReadByte(NO_ACK);                  //Read CRC SNA0/1 (CRC is not analyzed)
  return error;
SHT21.h code
#ifndef SHT2x_H
#define SHT2x_H
// File      :  SHT2x.h
// Author    :  MST
// Brief     :  Sensor layer. Definitions of commands and registers,
//              functions for sensor access
#include "system.h"
//  CRC
const u16t POLYNOMIAL = 0x131;  //P(x)=x^8+x^5+x^4+1 = 100110001
//coefficients relative humidity conversion for SHT2x (preproduction prototype sample)
//coefficients are scaled for 16 bit values
const ft c00=-7.7239;
const ft c10= 3.8219E-2/16;
const ft c01= 2.5329E-4/4;
const ft c20=-3.6634E-6/256;
const ft c11= 8.6345E-7/64;
//coefficients temperature conversion for SHT2x (preproduction prototype sample)
const ft c0 =-46.8375;
const ft c1 = 1.1072E-2/4;
const ft c2 =-2.1233E-8/16;
// sensor command
typedef enum{
  TRIG_T_MEASUREMENT_HM    = 0xE3, // command trig. temp meas. hold master
  TRIG_RH_MEASUREMENT_HM   = 0xE5, // command trig. humidity meas. hold master
  TRIG_T_MEASUREMENT_POLL  = 0xF3, // command trig. temp meas. no hold master
  TRIG_RH_MEASUREMENT_POLL = 0xF5, // command trig. humidity meas. no hold master
  USER_REG_W               = 0xE6, // command writing user register
  USER_REG_R               = 0xE7, // command reading user register
  SOFT_RESET               = 0xFE  // command soft reset
}etSHT2xCommand;
typedef enum {
  SHT2x_RES_12_14BIT       = 0x00, // RH=12bit, T=14bit
  SHT2x_RES_8_12BIT        = 0x01, // RH= 8bit, T=12bit
  SHT2x_RES_10_13BIT       = 0x80, // RH=10bit, T=13bit
  SHT2x_RES_11_11BIT       = 0x81, // RH=11bit, T=11bit
  SHT2x_RES_MASK           = 0x81  // Mask for res. bits (7,0) in user reg.
} etSHT2xResolution;
typedef enum {
  SHT2x_EOB_ON             = 0x40, // end of battery
  SHT2x_EOB_MASK           = 0x40, // Mask for EOB bit(6) in user reg.
} etSHT2xEob;
typedef enum {
  SHT2x_HEATER_ON          = 0x04, // heater on
  SHT2x_HEATER_OFF         = 0x00, // heater off
  SHT2x_HEATER_MASK        = 0x04, // Mask for Heater bit(2) in user reg.
} etSHT2xHeater;
// measurement signal selection
typedef enum{
  HUMIDITY,
  TEMP
}etSHT2xMeasureType;
typedef enum{
  I2C_ADR_W                = 128,   // sensor I2C address + write bit
  I2C_ADR_R                = 129    // sensor I2C address + read bit
}etI2cHeader;
u8t SHT2x_CheckCrc(u8t data[], u8t nbrOfBytes, u8t checksum);
// calculates checksum for n bytes of data and compares it with expected
// checksum
// input:  data[]       checksum is built based on this data
//         nbrOfBytes   checksum is built for n bytes of data
//         checksum     expected checksum
// return: error:       CHECKSUM_ERROR = checksum does not match
//                      0              = checksum matches
u8t SHT2x_ReadUserRegister(u8t *pRegisterValue);
// reads the SHT2x user register (8bit)
// input : -
// output: *pRegisterValue
// return: error
u8t SHT2x_WriteUserRegister(u8t *pRegisterValue);
// writes the SHT2x user register (8bit)
// input : *pRegisterValue
// output: -
// return: error
u8t SHT2x_MeasurePoll(etSHT2xMeasureType eSHT2xMeasureType, nt16 *pMeasurand);
// measures humidity or temperature. This function polls every 10ms until
// measurement is ready.
// input:  eSHT2xMeasureType
// output: *pMeasurand:  humidity / temperature as raw value
// return: error
// note:   timing for timeout may be changed
u8t SHT2x_MeasureHM(etSHT2xMeasureType eSHT2xMeasureType, nt16 *pMeasurand);
// measures humidity or temperature. This function waits for a hold master until
// measurement is ready or a timeout occurred.
// return: error
u8t SHT2x_SoftReset();
// performs a reset
// input:  -
// output: -
// return: error
float SHT2x_CalcRH(u16t u16sT, u16t u16sRH);
// calculates the relative humidity
// input:  sT:  temperature raw value (16bit scaled)
//         sRH: humidity raw value (16bit scaled)
// return: pHumidity relative humidity [%RH]
float SHT2x_CalcTemperatureC(u16t u16sT);
// calculates temperature
// return: temperature [°C]
u8t SHT2x_GetSerialNumber(u8t u8SerialNumber[]);
// gets serial number of SHT2x according application note "How To
// Read-Out the Serial Number"
// note:   readout of this function is not CRC checked
// input:  -
// output: u8SerialNumber: Array of 8 bytes (64Bits)
//         MSB                                         LSB
//         u8SerialNumber[7]             u8SerialNumber[0]
//         SNA_1 SNA_0 SNB_3 SNB_2 SNB_1 SNB_0 SNC_1 SNC_0
// return: error
system.c code
// File      :  System.c
// Author    :  MST
// Brief     :  System functions
#include "system.h"
void Init_HW (void)
  //-- initialize system clock of V850 (fcpu = fosc, no PLL) --
  PRCMD = 0x00;   // unlock PCC register
  PCC = 0x00;     // perform settings in PCC register
  RCM = 0x01;     // disable ring oscillator
  //-- watchdog --
  WDTM2 = 0x0f;   // stop watchdog
  //-- interrupts --
  __EI();         // enable interrupts for debugging with minicube
  //Settings for debugging with Sensirion EKH4 and minicube2, power up sensor
  //Not needed for normal use
  PMDLL = 0xF0;
  PDLL  = 0x04;
#pragma optimize = s none
void DelayMicroSeconds (u32t nbrOfUs)
  for(u32t i=0; i<nbrOfUs; i++)
  {  //__asm("nop");  //nop's may be added for timing adjustment
SHT21.H CODE
#ifndef SYSTEM_H
#define SYSTEM_H
// File      :  System.h
// Author    :  MST
// Brief     :  System functions, global definitions
#include "io70f3740.h"             // controller register definitions
#include <assert.h>                // assert functions
#include <intrinsics.h>            // low level microcontroller commands
#include "typedefs.h"              // type definitions
// Error codes
typedef enum{
  ACK_ERROR                = 0x01,
  TIME_OUT_ERROR           = 0x02,
  CHECKSUM_ERROR           = 0x04,
  UNIT_ERROR               = 0x08
}etError;
void Init_HW (void);
// Initializes the used hardware
void DelayMicroSeconds (u32t nbrOfUs);
// wait function for small delays
// input:  nbrOfUs   wait x times approx. one micro second (fcpu = 4MHz)
// return: -
// note: smallest delay is approx. 30us due to function call
TYPEDEFS.C CODE
#ifndef TYPEDEFS_H
#define TYPEDEFS_H
// File      :  typedefs.h
// Author    :  MST
// Brief     :  Definitions of typedefs for good readability and portability
//Processor endian system
//#define BIG ENDIAN   //e.g. Motorola (not tested at this time)
#define LITTLE_ENDIAN  //e.g. PIC, 8051, NEC V850
// basic types: making the size of types clear
typedef unsigned char   u8t;      ///< range: 0 .. 255
typedef signed char     i8t;      ///< range: -128 .. +127
typedef unsigned short  u16t;     ///< range: 0 .. 65535
typedef signed short    i16t;     ///< range: -32768 .. +32767
typedef unsigned long   u32t;     ///< range: 0 .. 4'294'967'295
typedef signed long     i32t;     ///< range: -2'147'483'648 .. +2'147'483'647
typedef float           ft;       ///< range: +-1.18E-38 .. +-3.39E+38
typedef double          dt;      ///< range:            .. +-1.79E+308
typedef bool            bt;       ///< values: 0, 1 (real bool used)
typedef union {
  u16t u16;               // element specifier for accessing whole u16
  i16t i16;               // element specifier for accessing whole i16
  struct {
    #ifdef LITTLE_ENDIAN  // Byte-order is little endian
    u8t u8L;              // element specifier for accessing low u8
    u8t u8H;              // element specifier for accessing high u8
    #else                 // Byte-order is big endian
    u8t u8H;              // element specifier for accessing low u8
    u8t u8L;              // element specifier for accessing high u8
  } s16;                  // element spec. for acc. struct with low or high u8
} nt16;
typedef union {
  u32t u32;               // element specifier for accessing whole u32
  i32t i32;               // element specifier for accessing whole i32
 struct {
    u16t u16L;            // element specifier for accessing low u16
    u16t u16H;            // element specifier for accessing high u16
    u16t u16H;            // element specifier for accessing low u16
    u16t u16L;            // element specifier for accessing high u16
  } s32;                  // element spec. for acc. struct with low or high u16
} nt32;
The code for the display is not too necesary. I am interfacing it with a PC through serial COM port, using max233.
Crosslink
PIC to be used
PostPosted: Tue Feb 23, 2010 4:36 pm     Reply with quote
I omitted the PIC I intend to use with the driver. I would like to use PIC18F series. Any of them will do, say PIC18F4550. Thanks
