This is a little off topic, I know, but I get my best ideas from you guys.
I have found that my microcontroller resets or goes wacky when there is an electrostatic discharge nearby (not to the board or wires).
I am not using a four-layer PCB.
Any ideas as to what on the PIC18F4550 might be sensitive? Any ideas how to fix this?
Thanks!
Posted: Sat Jan 16, 2010 7:12 pm
Search the forum archives for this:
ESD MCLR
Set it to: Search for all terms
SherpaDoug
Posted: Sun Jan 17, 2010 6:59 am
Any wire can act as an antenna to pick up ESD. Longer wires are worse. Read up on ESD Prevention, and add bypass caps or PI filters to the likely suspects. _________________ The search for better is endless. Instead simply find very good and get the job done.
