on7nh
troubles with GLCD display |
Posted: Sun Nov 22, 2009 10:15 am |
hello folks,
I have some trouble with a glcd, HQM1286404.
I am using this with the HDM64GS12.c driver.
All is running ok, but for some strange reason, the display switches after
some time to 1/2 and I can do nothing else than a displayinit(;) to become a normal display.
Resetting the display_unit is possible, but then I have a flickering display.
Any suggestions?
#include <18F452.h>
#fuses HS,WDT,NOLVP
#use delay(clock=1600000)
#use i2c(SLAVE, SDA=PIN_C4, SCL=PIN_C3, address=0xa0,SLOW)
#include <HDM64GS12.c>
#include <graphics.c>
#include <math.h>
// global variables
BYTE address, buffer[0x10];
char TextSpanning[] = "Spanning :";
char TextStroom[]= "Stroom :";
char Textvermogen[]= "P : ";
char TextFrequentie[]= "Hz : ";
unsigned int16 measU;
unsigned int16 bargraph;
unsigned int16 measI;
unsigned int32 measPower;
unsigned int16 Power;
unsigned int32 Freq;
unsigned int16 runstatus;
char lcddata[20];
int32 count,tel;
int16 keyw;
void Prnt_display();
BYTE incoming, state;
BYTE B1, B2, B3, B4;
#int_rtcc
void clock_isr()
//disable_interrupts(GLOBAL);
if (tel < 10)
tel++;
tel = 0;
Prnt_display();
// enable_interrupts(GLOBAL);
#INT_SSP
void ssp_interupt ()
state = i2c_isr_state();
if(state <= 0x80) //Master is sending data
incoming = i2c_read();
if(state == 3)
keyw = incoming;
if(state == 1)
b1 = incoming;
if(state == 2)
b2 = incoming;
if(keyw == 101)
//tempvar = make16(b2,b1);
power = make16(b2,b1);
keyw = 0;
if(keyw == 102)
MeasU = make16(b2,b1);
keyw = 0;
if(keyw == 103)
MeasI = make16(b2,b1);
keyw = 0;
if(keyw == 104)
Freq = make16(b2,b1);
keyw = 0;
if(keyw == 105)
bargraph = make16(b2,b1);
keyw = 0;
if(keyw == 106)
runstatus = make16(b2,b1);
keyw = 0;
if(keyw == 111)
// D_CY = tempvar;
keyw = 0;
if(keyw == 111)
// D_CY = tempvar;
keyw = 0;
if(state == 0x80) //Master is requesting data
i2c_write(buffer[address]);
// Prnt_display();
void Prnt_display()
// glcd_init(ON);
glcd_rect(0, 0, 127, 63, NO, ON); // Outline the display
glcd_text57(3, 2, TextSpanning, 1, ON); // Display "gemeten Spanning"
glcd_text57(3, 12, TextStroom, 1, ON); // Display "gemeten stroom"
glcd_text57(3, 22, TextVermogen, 1, ON); // Display "ingesteld vermogen"
glcd_text57(3, 32, TextFrequentie, 1, ON); // Display "Ingestelde Frequentie"
// Zet gemeten spanning op display
sprintf(lcddata,"%lu",MeasU);
glcd_rect(65, 2, 126, 8, YES,OFF); // oude waarde wissen
glcd_text57(65,2,lcddata,1,on);
// Zet gemeten stroom op display
sprintf(lcddata,"%lu",measI);
glcd_rect(65, 12, 126, 18, YES,OFF); // oude waarde wissen
glcd_text57(65,12,lcddata,1,on);
// Zet ingesteld vermogen op display
sprintf(lcddata,"%lu",power);
glcd_rect(45, 22, 79, 28, YES, OFF); // oude waarde wissen
glcd_text57(45,22,lcddata,1,on);
// Zet berekend vermogen op display
measpower = measU * (measI/1000.0);
sprintf(lcddata,"%lu²²²",measPower);
glcd_rect(80, 22, 126, 28, YES, OFF); // oude waarde wissen
glcd_text57(80,22,lcddata,1,on);
sprintf(lcddata,"%lu",freq*10);
glcd_rect(45, 32, 126, 38, YES, OFF); // oude waarde wissen
glcd_text57(45,32,lcddata,1,on);
// sprintf(lcddata,"%lu",keyw);
// glcd_rect(45, 42, 126, 48, YES, OFF); // oude waarde wissen
// glcd_text57(45,42,lcddata,1,on);
if (runstatus != 1)
glcd_rect(1, 52, 126, 58, YES, ON); // oude waarde wissen
// waarde mag varieren tussen 1 en 81
glcd_rect(1, 52, 126, 58, YES, OFF); // oude waarde wissen
glcd_rect(1, 52, 126, 58, NO, ON); // oude waarde wissen
glcd_line(63,52,63,58,ON);
glcd_line((1+(bargraph/33)),52,(1+(bargraph/33)),58,ON);
set_tris_a(0b11000001);
// setup_wdt(WDT_72MS);
setup_counters(RTCC_internal,Rtcc_div_32 | Rtcc_8_bit);
enable_interrupts(INT_RTCC);
enable_interrupts(INT_SSP);
glcd_init(ON); // Must initialize the LCD
while (TRUE)
// Prnt_display();
delay_ms(200);
count++;
if (count > 10)
count = 0;
// glcd_init(ON); // Must initialize the LCD
restart_wdt();//at least one in the main while(1) loop
} //end while(true)
} //end void(main)
Posted: Sun Nov 22, 2009 10:23 am |
Quote: |
#include <18F452.h>
#fuses HS,WDT,NOLVP
Look closely at your specified frequency. Does it match your crystal ? |
Posted: Sun Nov 22, 2009 10:42 am |
Oops... i will test this ...  |
Posted: Sun Nov 22, 2009 10:50 am |
I did change the freq... this was wrong,
now I see still flickering in the display.. it seems that wdt is working.
After changing WDT into NOWDT, the cpu hangs....
Maybe is this the problem i am struggling. |
Posted: Sun Nov 22, 2009 1:44 pm |
Have you tested your LCD code and your i2c slave code separately ?
Make them work correctly as separate programs and then combine them. |
