troubles with GLCD display
on7nh
View user's profile Send private message Visit poster's website MSN Messenger
PostPosted: Sun Nov 22, 2009 10:15 am     Reply with quote
hello folks,
I have some trouble with a glcd, HQM1286404.
I am using this with the HDM64GS12.c driver.
All is running ok, but for some strange reason, the display switches after
some time to 1/2 and I can do nothing else than a displayinit(;) to become a normal display.
Resetting the display_unit is possible, but then I have a flickering display.
Any suggestions?
#include <18F452.h>
#fuses HS,WDT,NOLVP
#use delay(clock=1600000)
#use i2c(SLAVE, SDA=PIN_C4, SCL=PIN_C3, address=0xa0,SLOW)
#include <HDM64GS12.c>
#include <graphics.c>
#include <math.h>
// global variables
   BYTE address, buffer[0x10];
      char TextSpanning[] =    "Spanning :";
      char TextStroom[]=       "Stroom   :";
      char Textvermogen[]=    "P     : ";
      char TextFrequentie[]=    "Hz    : ";
   unsigned int16    measU;
   unsigned int16   bargraph;
   unsigned int16     measI;
   unsigned int32    measPower;
   unsigned int16   Power;
   unsigned int32 Freq;
   unsigned int16    runstatus;
   char lcddata[20];
   int32 count,tel;
   int16 keyw;
   void Prnt_display();
      BYTE incoming, state;
   BYTE B1, B2, B3, B4;
#int_rtcc
void clock_isr()
   //disable_interrupts(GLOBAL);
   if (tel < 10)
      tel++;
         tel = 0;
         Prnt_display();
   //      enable_interrupts(GLOBAL);
#INT_SSP
void ssp_interupt ()
      state = i2c_isr_state();
    if(state <= 0x80)                     //Master is sending data
      incoming = i2c_read();
         if(state == 3)
            keyw = incoming;
         if(state == 1)
            b1 = incoming;
         if(state == 2)
            b2 = incoming;
       if(keyw == 101)
//tempvar = make16(b2,b1);
         power = make16(b2,b1);
         keyw = 0;
       if(keyw == 102)
         MeasU = make16(b2,b1);
         keyw = 0;
       if(keyw == 103)
         MeasI = make16(b2,b1);
         keyw = 0;
       if(keyw == 104)
         Freq = make16(b2,b1);
         keyw = 0;
       if(keyw == 105)
         bargraph = make16(b2,b1);
         keyw = 0;
       if(keyw == 106)
         runstatus = make16(b2,b1);
         keyw = 0;
       if(keyw == 111)
   //      D_CY = tempvar;
         keyw = 0;
       if(keyw == 111)
   //      D_CY = tempvar;
         keyw = 0;
   if(state == 0x80)                     //Master is requesting data
      i2c_write(buffer[address]);
//   Prnt_display();
void Prnt_display()
          //   glcd_init(ON);
         glcd_rect(0, 0, 127, 63, NO, ON);           // Outline the display
         glcd_text57(3,  2, TextSpanning, 1, ON);     // Display "gemeten Spanning"
         glcd_text57(3, 12, TextStroom, 1, ON);      // Display "gemeten stroom"
         glcd_text57(3, 22, TextVermogen, 1, ON);    // Display "ingesteld vermogen"
         glcd_text57(3, 32, TextFrequentie, 1, ON);  // Display "Ingestelde Frequentie"
         // Zet gemeten spanning op display
         sprintf(lcddata,"%lu",MeasU);
         glcd_rect(65, 2, 126, 8, YES,OFF);         // oude waarde wissen
         glcd_text57(65,2,lcddata,1,on);
         // Zet gemeten stroom op display
         sprintf(lcddata,"%lu",measI);
         glcd_rect(65, 12, 126, 18, YES,OFF);         // oude waarde wissen
         glcd_text57(65,12,lcddata,1,on);
         // Zet ingesteld vermogen op display
         sprintf(lcddata,"%lu",power);
         glcd_rect(45, 22, 79, 28, YES, OFF);         // oude waarde wissen
         glcd_text57(45,22,lcddata,1,on);
         // Zet berekend vermogen op display
         measpower = measU * (measI/1000.0);
         sprintf(lcddata,"%lu²²²",measPower);
         glcd_rect(80, 22, 126, 28, YES, OFF);         // oude waarde wissen
         glcd_text57(80,22,lcddata,1,on);
         sprintf(lcddata,"%lu",freq*10);
         glcd_rect(45, 32, 126, 38, YES, OFF);         // oude waarde wissen
         glcd_text57(45,32,lcddata,1,on);
   //      sprintf(lcddata,"%lu",keyw);
   //      glcd_rect(45, 42, 126, 48, YES, OFF);         // oude waarde wissen
   //      glcd_text57(45,42,lcddata,1,on);
         if (runstatus != 1)
                        glcd_rect(1, 52, 126, 58, YES, ON);         // oude waarde wissen
                        // waarde mag varieren tussen 1 en 81
                        glcd_rect(1, 52, 126, 58, YES, OFF);         // oude waarde wissen
                        glcd_rect(1, 52, 126, 58, NO, ON);         // oude waarde wissen
                        glcd_line(63,52,63,58,ON);
                        glcd_line((1+(bargraph/33)),52,(1+(bargraph/33)),58,ON);
      set_tris_a(0b11000001);
   //   setup_wdt(WDT_72MS);
      setup_counters(RTCC_internal,Rtcc_div_32 | Rtcc_8_bit);
      enable_interrupts(INT_RTCC);
       enable_interrupts(INT_SSP);
      glcd_init(ON);                                // Must initialize the LCD
      while (TRUE)
      //   Prnt_display();
         delay_ms(200);
         count++;
         if (count > 10)
               count = 0;
            //   glcd_init(ON);                                // Must initialize the LCD
         restart_wdt();//at least one in the main while(1) loop
         }   //end while(true)
}         //end void(main)
PostPosted: Sun Nov 22, 2009 10:23 am     Reply with quote
#include <18F452.h>
#fuses HS,WDT,NOLVP
Look closely at your specified frequency. Does it match your crystal ?
PostPosted: Sun Nov 22, 2009 10:42 am     Reply with quote
Oops... i will test this ... Embarassed
PostPosted: Sun Nov 22, 2009 10:50 am     Reply with quote
I did change the freq... this was wrong,
now I see still flickering in the display.. it seems that wdt is working.
After changing WDT into NOWDT, the cpu hangs....
Maybe is this the problem i am struggling.
PostPosted: Sun Nov 22, 2009 1:44 pm     Reply with quote
Have you tested your LCD code and your i2c slave code separately ?
Make them work correctly as separate programs and then combine them.
