Program PIC to interface 2x16 LCD using C code & LCD.c
karthi27
PostPosted: Wed Nov 18, 2009 5:49 am     Reply with quote
Am using PIC 16f72 and PIC 16f877. Working on it for my project. Using C language for programming.
Now I need to program my chip to interface a 2x16 LCD.
Wrote a simple code to display a "Hello" message.
Oops... it didn't work. Included the program below.
Nothing is wrong with my LCD module, chip and programmmer (ICD2) and pin connections are correct.
Using MPLAB IDE and CCS C.
Before burning, I included the LCD.c file under other files.
Please guide me in this concern to rectify the error.
Regards
Karthi
karthi27
Writing an LCD prog without drivers
PostPosted: Wed Nov 18, 2009 5:58 am     Reply with quote
Plz help me writing a simple LCD prog to display a "Hello" message without using driver files.
Regards
Karthi
mskala
PostPosted: Wed Nov 18, 2009 9:09 am     Reply with quote
Not all LCD modules are the same. Some things to check are:
Do you need to wait a certain amount of time after power-up before
doing anything? Are the delays in the code enough? Does your LCD
require any different or extra initialization commands? Are you sure you
have your contrast/backlight correct?
Mark S.
PostPosted: Wed Nov 18, 2009 2:13 pm     Reply with quote
This post has several links to threads about LCD problems.
Read them all and you will probably find the problem.
http://www.ccsinfo.com/forum/viewtopic.php?t=32244&start=6
Re: LCD.c file
PostPosted: Wed Nov 18, 2009 2:46 pm     Reply with quote
karthi27 wrote:
//// (C) Copyright 1996,2007 Custom Computer Services ////
//// This source code may only be used by licensed users of the CCS C ////
//// compiler. This source code may only be distributed to other ////
//// licensed users of the CCS C compiler. No other use, reproduction ////
//// or distribution is permitted without written permission. ////
You are not supposed to publish this code! What is the part you didn't understand?
There is no need to post the code. Everybody using the CCS compiler already has it.
