		| Author | Message |
		| karthi27
				| Program PIC to interface 2x16 LCD using C code & LCD.c |
				|  Posted: Wed Nov 18, 2009 5:49 am |   |
				| Am using PIC 16f72 and PIC 16f877. Working on it for my project. Using C language for programming. Now I need to program my chip to interface a 2x16 LCD.
 Wrote a simple code to display a "Hello" message.
 Oops... it didn't work. Included the program below.
 Nothing is wrong with my LCD module, chip and programmmer (ICD2) and pin connections are correct.
 Using MPLAB IDE and CCS C.
 Before burning, I included the LCD.c file under other files.
 Please guide me in this concern to rectify the error.
 Regards
 Karthi
		| karthi27
				| Writing an LCD prog without drivers |
				|  Posted: Wed Nov 18, 2009 5:58 am |   |
				| Plz help me writing a simple LCD prog to display a "Hello" message without using driver files. _________________
 Regards
 Karthi
		| mskala
				|  Posted: Wed Nov 18, 2009 9:09 am |   |
				| Not all LCD modules are the same.  Some things to check are: Do you need to wait a certain amount of time after power-up before
 doing anything?  Are the delays in the code enough?  Does your LCD
 require any different or extra initialization commands?  Are you sure you
 have your contrast/backlight correct?
 Mark S.
		| PCM programmer
		| ckielstra
				| Re: LCD.c file |
				|  Posted: Wed Nov 18, 2009 2:46 pm |   |
				| You are not supposed to publish this code! What is the part you didn't understand? 	  | karthi27 wrote: |  	  | //// (C) Copyright 1996,2007 Custom Computer Services //// //// This source code may only be used by licensed users of the CCS C ////
 //// compiler. This source code may only be distributed to other ////
 //// licensed users of the CCS C compiler. No other use, reproduction ////
 //// or distribution is permitted without written permission. ////
 There is no need to post the code. Everybody using the CCS compiler already has it.
