controller 3 phase motor with PWM
filjoa
PostPosted: Thu Oct 22, 2009 4:56 am     Reply with quote
hi
I need controller 3 phase motor with PWM, I connect my PIC on IRF and it close circuit with an resistor (10Ohm/ 150W) to brake motor (reduce speed)...
But how I can know value of PWM?
I have this configuration on my program:
setup_ccp1(CCP_PWM);
setup_timer_2(T2_DIV_BY_4, 255, 1);
set_pwm1_duty(0); //max speed
set_pwm1_duty(255); //min speed
I don't know how frequency I stay work with PWM.
PS: I use PIC18F252 with clock 20Mhz
best regards
PostPosted: Thu Oct 22, 2009 12:02 pm     Reply with quote
PWM frequency forumla:
http://www.ccsinfo.com/forum/viewtopic.php?t=17993
filjoa
PostPosted: Thu Oct 22, 2009 5:16 pm     Reply with quote
Hi
My frequency with this configurations is 4901hz correct?
I test it and I have very noise when I try set_pwm1_duty(1) at set_pwm1_duty(175).
How I can reduce this noise?
PS: I think put frequency more than 20Khz but I don't know how make that.
best regards
PostPosted: Fri Oct 23, 2009 2:33 pm     Reply with quote
That's close enough to the calculated frequency.
I don't know what you mean by "noise". You should see a clean pulse
on the oscilloscope.
Did you take Algebra ? Use the equation in the link that I gave you.
Set the Timer2 Divisor value to 1, in the setup_timer_2() function.
Then solve the equation for PR2. It will give you the value to use
for the middle parameter in setup_timer_2().
filjoa
PostPosted: Fri Oct 23, 2009 6:14 pm     Reply with quote
Hi
noise is "iiiiiiiiiiiiiiiii" when I try break motor...
I have must algebra... but I don't know with is possible use divide timer for 1. I don't read this part of the post...
But now stay all ok, thanks
