My frequency with this configurations is 4901hz correct?
I test it and I have very noise when I try set_pwm1_duty(1) at set_pwm1_duty(175).
How I can reduce this noise?
PS: I think put frequency more than 20Khz but I don't know how make that.
best regards
Posted: Fri Oct 23, 2009 2:33 pm
That's close enough to the calculated frequency.
I don't know what you mean by "noise". You should see a clean pulse
on the oscilloscope.
Did you take Algebra ? Use the equation in the link that I gave you.
Set the Timer2 Divisor value to 1, in the setup_timer_2() function.
Then solve the equation for PR2. It will give you the value to use
for the middle parameter in setup_timer_2().
filjoa
Posted: Fri Oct 23, 2009 6:14 pm
Hi
noise is "iiiiiiiiiiiiiiiii" when I try break motor...
I have must algebra... but I don't know with is possible use divide timer for 1. I don't read this part of the post...
