PWM, who is wrong?
mbalderas
PWM, who is wrong?
PostPosted: Sun Oct 11, 2009 10:31 pm     Reply with quote
With a PIC18F2550, I want to create a PWM.
I don't know what is going on... I just want to know if this is an issue of the compiler or, what's wrong. I want to pass the value of the duty cycle through a variable.
Like in:
int16 var;
var=100;
set_pwm1_duty(var);
But this doesn't work, the compiler doesn't find errors but in the real world, the output is always low. If I do it with a constant it works fine.
set_pwm1_duty(100);
Has anyone experienced something similar? How to know if the compiler's wrong?
PostPosted: Sun Oct 11, 2009 10:38 pm     Reply with quote
int16 var;
var=100;
set_pwm1_duty(var);
In this case you are using 10-bit mode for the PWM, because you
declared 'var' as 16 bits.
set_pwm1_duty(100);
In this case you are using 8-bit mode.
int8 var;
var=100;
set_pwm1_duty(var);
To make the 1st case be the same as the 2nd case, you need to
declare 'var' as 8 bits, as shown above in bold.
mbalderas
PostPosted: Sun Oct 11, 2009 11:06 pm     Reply with quote
Thanks PCM Prog, but it still doesn't go... Is there any way to test it assigning the values directly to the CCPR1L and CCP1CON? Because I'm guessing the compiler is the issue.
Thanks for your time
PostPosted: Sun Oct 11, 2009 11:24 pm     Reply with quote
Post a short but complete test program. It should compile without errors.
Example of a PWM test program:
http://www.ccsinfo.com/forum/viewtopic.php?t=17729&start=1
Also post your compiler version.
mbalderas
PostPosted: Sun Oct 11, 2009 11:25 pm     Reply with quote
4.038
mbalderas
PostPosted: Sun Oct 11, 2009 11:42 pm     Reply with quote
Look:
#use delay(clock=8000000)
   int8 var;
   set_tris_a(0xFF);
   setup_adc(ADC_OFF);
   setup_spi(SPI_SS_DISABLED);
   setup_wdt(WDT_OFF);
   setup_timer_0(RTCC_INTERNAL);
   setup_timer_1(T1_DISABLED);
   setup_timer_2(T2_DIV_BY_16,255,16);
   setup_ccp1(CCP_PWM);
   setup_vref(FALSE);
//Setup_Oscillator parameter not selected from Intr Oscillotar Config tab
   var=50;
   set_pwm1_duty(var);
But if I assign it directly:
  set_pwm1_duty(50);
Works.
PostPosted: Mon Oct 12, 2009 12:18 am     Reply with quote
1. Post your fuses statement.
2. Are you testing this on a board, or is it in Proteus ?
mbalderas
PostPosted: Mon Oct 12, 2009 9:21 am     Reply with quote
#include <18F2550.h>
#device adc=8
#FUSES HS                       //High speed Osc (> 4mhz)
#FUSES BORV20                   //Brownout reset at 2.0V
#FUSES NOPUT                    //No Power Up Timer
#FUSES NOPBADEN                 //PORTB pins are configured as digital I/O on RESET
#FUSES NOEBTRB                  //Boot block not protected from table reads
#FUSES NOCPB                    //No Boot Block code protection
#FUSES MCLR                     //Master Clear pin enabled
#FUSES LPT1OSC                  //Timer1 configured for low-power operation
#FUSES XINST                    //Extended set extension and Indexed Addressing mode enabled
#FUSES PLL2                     //Divide By 2(8MHz oscillator input)
#FUSES CPUDIV1                  //No System Clock Postscaler
#FUSES USBDIV                   //USB clock source comes from PLL divide by 2
#FUSES VREGEN                   //USB voltage regulator enabled
I'm using Proteus before going to the board.
Thanks!
PostPosted: Mon Oct 12, 2009 11:36 am     Reply with quote
#FUSES XINST
Don't use XINST. It will make your program behave erratically.
Always use NOXINST.
mbalderas
PostPosted: Mon Oct 12, 2009 2:10 pm     Reply with quote
Gosh, you're a genius! It's working now!
What is that fuse for? I didn't write it, it came from the Wiz...
PostPosted: Mon Oct 12, 2009 2:14 pm     Reply with quote
XINST enables the Extended Instruction Set in the 18F2550. But the
CCS compiler doesn't support it. It's a bug in the Wizard to enable it.
