mbalderas Guest
PWM, who is wrong? |
Posted: Sun Oct 11, 2009 10:31 pm |
With a PIC18F2550, I want to create a PWM.
I don't know what is going on... I just want to know if this is an issue of the compiler or, what's wrong. I want to pass the value of the duty cycle through a variable.
Like in:
int16 var;
var=100;
set_pwm1_duty(var);
But this doesn't work, the compiler doesn't find errors but in the real world, the output is always low. If I do it with a constant it works fine.
set_pwm1_duty(100);
Has anyone experienced something similar? How to know if the compiler's wrong? |
Posted: Sun Oct 11, 2009 10:38 pm |
Quote: |
int16 var;
var=100;
set_pwm1_duty(var);
In this case you are using 10-bit mode for the PWM, because you
declared 'var' as 16 bits.
Quote: | set_pwm1_duty(100); |
In this case you are using 8-bit mode.
Quote: |
int8 var;
var=100;
set_pwm1_duty(var);
To make the 1st case be the same as the 2nd case, you need to
declare 'var' as 8 bits, as shown above in bold. |
mbalderas Guest
Posted: Sun Oct 11, 2009 11:06 pm |
Thanks PCM Prog, but it still doesn't go... Is there any way to test it assigning the values directly to the CCPR1L and CCP1CON? Because I'm guessing the compiler is the issue.
Thanks for your time |
mbalderas Guest
Posted: Sun Oct 11, 2009 11:25 pm |
4.038 |
mbalderas Guest
Posted: Sun Oct 11, 2009 11:42 pm |
Look:
#use delay(clock=8000000)
int8 var;
set_tris_a(0xFF);
setup_adc(ADC_OFF);
setup_spi(SPI_SS_DISABLED);
setup_wdt(WDT_OFF);
setup_timer_0(RTCC_INTERNAL);
setup_timer_1(T1_DISABLED);
setup_timer_2(T2_DIV_BY_16,255,16);
setup_ccp1(CCP_PWM);
setup_vref(FALSE);
//Setup_Oscillator parameter not selected from Intr Oscillotar Config tab
var=50;
set_pwm1_duty(var);
But if I assign it directly:
Works. |
Posted: Mon Oct 12, 2009 12:18 am |
1. Post your fuses statement.
2. Are you testing this on a board, or is it in Proteus ? |
mbalderas Guest
Posted: Mon Oct 12, 2009 9:21 am |
Code: | #include <18F2550.h>
#device adc=8
#FUSES HS //High speed Osc (> 4mhz)
#FUSES BORV20 //Brownout reset at 2.0V
#FUSES NOPBADEN //PORTB pins are configured as digital I/O on RESET
#FUSES XINST //Extended set extension and Indexed Addressing mode enabled
#FUSES PLL2 //Divide By 2(8MHz oscillator input)
#FUSES CPUDIV1 //No System Clock Postscaler
#FUSES USBDIV //USB clock source comes from PLL divide by 2
#FUSES VREGEN //USB voltage regulator enabled
#use delay(clock=8000000) |
I'm using Proteus before going to the board.
Thanks! |
Posted: Mon Oct 12, 2009 11:36 am |
Don't use XINST. It will make your program behave erratically.
Always use NOXINST. |
mbalderas Guest
Posted: Mon Oct 12, 2009 2:10 pm |
Gosh, you're a genius! It's working now!
What is that fuse for? I didn't write it, it came from the Wiz... |
Posted: Mon Oct 12, 2009 2:14 pm |
XINST enables the Extended Instruction Set in the 18F2550. But the
CCS compiler doesn't support it. It's a bug in the Wizard to enable it. |
