albe9990
10f206 |
Posted: Tue Sep 15, 2009 7:00 am |
hallo I am begin program my new pic 10f206 and I have test same code blink led in this forum, but never is good. There is same code correct so I begin ?
#include <10F206.h>
#FUSES NOMCLR //Master Clear pin: disable
#FUSES NOPROTECT //Code protected from reads
#define LED PIN_B0
main()
int32 timer;
setup_comparator(NC_NC);
output_low(PIN_B0);
output_low(PIN_B1);
output_low(PIN_B2);
output_low(PIN_B3);
// delay_ms(500); // <--- uncomment this and we will *never* get below this code
while(true)
output_high(LED); // LED DOES turn on
delay_ms(500); // locked up?
output_low(LED); // never makes it here...
I have tried this but don't work.
Thanks everyone. |
Posted: Tue Sep 15, 2009 12:47 pm |
Post your compiler version. It's a number in this format: x.xxx
It's given at the top of the .LST file, which is in your project directory. |
Posted: Wed Sep 16, 2009 1:37 am |
CCS PCB C Compiler, Version 4.084 |
albe9990
Posted: Wed Sep 16, 2009 1:45 am |
sorry CCS PCB C Compiler, Version 4.084
and in the Pickit2 when i open file write :
no configurations world in hex file ... |
albe9990
Posted: Wed Sep 16, 2009 4:38 am |
Now I have test this code:
#include <10F206.h>
main()
setup_wdt(WDT_2304MS);
output_high(PIN_B2); // turn on LED
restart_wdt();
delay_ms(100); // lets delay.
output_low(PIN_B2); // turn off LED
restart_wdt();
and the led came to blink and all is good
but without wdt nothing to.
stop in the first delay.
Thanks. |
Posted: Wed Sep 16, 2009 4:17 pm |
I don't understand your post. Is there a problem with the Watchdog
Timer ?
I only have the version of PCB that comes with MPLAB. It's vs. 4.073.
I compiled the following program and looked at the .LST file. It looks OK.
I think this program should work.
#include <10F206.H>
#fuses NOWDT,NOMCLR
// Blink an LED on pin B2.
output_low(PIN_B2);
albe9990
Posted: Wed Sep 16, 2009 5:05 pm |
now is good with mplab.
and led blink.
Thanks |
