10f206
albe9990
10f206
PostPosted: Tue Sep 15, 2009 7:00 am     Reply with quote
hallo I am begin program my new pic 10f206 and I have test same code blink led in this forum, but never is good. There is same code correct so I begin ?
#include <10F206.h>
#FUSES NOMCLR                     //Master Clear pin: disable
#FUSES NOPROTECT                  //Code protected from reads
#define LED PIN_B0
main()
    int32   timer;
    setup_comparator(NC_NC);
    output_low(PIN_B0);
    output_low(PIN_B1);
    output_low(PIN_B2);
    output_low(PIN_B3);
//    delay_ms(500);    // <--- uncomment this and we will *never* get below this code
    while(true)
        output_high(LED);   // LED DOES turn on
        delay_ms(500);      // locked up?
        output_low(LED);    // never makes it here...
I have tried this but don't work.
Thanks everyone.
PostPosted: Tue Sep 15, 2009 12:47 pm     Reply with quote
Post your compiler version. It's a number in this format: x.xxx
It's given at the top of the .LST file, which is in your project directory.
PostPosted: Wed Sep 16, 2009 1:37 am     Reply with quote
CCS PCB C Compiler, Version 4.084
albe9990
PostPosted: Wed Sep 16, 2009 1:45 am     Reply with quote
sorry CCS PCB C Compiler, Version 4.084
and in the Pickit2 when i open file write :
no configurations world in hex file ...
albe9990
PostPosted: Wed Sep 16, 2009 4:38 am     Reply with quote
Now I have test this code:
#include <10F206.h>
main()
    setup_wdt(WDT_2304MS);
        output_high(PIN_B2);    // turn on LED
        restart_wdt();
        delay_ms(100);           // lets delay.
        output_low(PIN_B2);     // turn off LED
        restart_wdt();
and the led came to blink and all is good
but without wdt nothing to.
stop in the first delay.
Thanks.
PostPosted: Wed Sep 16, 2009 4:17 pm     Reply with quote
I don't understand your post. Is there a problem with the Watchdog
Timer ?
I only have the version of PCB that comes with MPLAB. It's vs. 4.073.
I compiled the following program and looked at the .LST file. It looks OK.
I think this program should work.
#include <10F206.H>
#fuses NOWDT,NOMCLR
// Blink an LED on pin B2.
   output_low(PIN_B2);
albe9990
PostPosted: Wed Sep 16, 2009 5:05 pm     Reply with quote
now is good with mplab.
and led blink.
