x>>15
sir_jfreyes
x>>15
PostPosted: Sun Aug 23, 2009 12:56 pm     Reply with quote
What is the best code in CCS for the instruction x>>15?
PostPosted: Sun Aug 23, 2009 1:55 pm     Reply with quote
Probably depends on how large the data is.
For 16bit data, it'd probably be faster to just perform a bit test, on the top bit, and just output the result of this (0/1).
For larger data types, you really have no choice but to use the shift.
bkamen
PostPosted: Mon Aug 24, 2009 12:36 am     Reply with quote
unsigned int16 var;
unsigned int8 x;
var = 0x8000;
x = make8 ( var, 1);
if (x & 0x80) {
    do something;
} else {
    do something else;
also works is:
if (var & 0x8000) {
  do something;
