What is the best code in CCS for the instruction x>>15?
Posted: Sun Aug 23, 2009 1:55 pm
Probably depends on how large the data is.
For 16bit data, it'd probably be faster to just perform a bit test, on the top bit, and just output the result of this (0/1).
For larger data types, you really have no choice but to use the shift.
bkamen
Posted: Mon Aug 24, 2009 12:36 am
unsigned int16 var;
unsigned int8 x;
var = 0x8000;
x = make8 ( var, 1);
if (x & 0x80) {
do something;
} else {
do something else;
also works is:
if (var & 0x8000) {
do something;
_________________ Dazed and confused? I don't think so. Just "plain lost" will do. :D
