unni.anad
Interrupt handling |
Posted: Fri Aug 14, 2009 9:49 am |
Whether ccs compiler itself take care of saving the W-REG and STATUS reg during when it serves an interrupt routine. In an example code provided it is shown as to be done by the programmer. (given in ALP).
#asm
//store current state of processor
MOVWF save_w
SWAPF status,W
BCF status,5
BCF status,6
MOVWF save_status
// Save anything else your code may change
// You need to do something with PCLATH if you have GOTOs
// remember to check to see what interrupt fired if using more than one!!
// code for isr
BCF t0if
INCF counter,F
BTFSC zero_flag
INCF (&counter+1),F
// restore processor and return from interrupt
SWAPF save_status,W
MOVWF status
SWAPF save_w,F
SWAPF save_w,W
#endasm |
In an another example using C
#INT_TIMER2 //HIGH
void timer2_isr()
count++;
What is the difference ? |
unni.anad
Posted: Fri Aug 14, 2009 11:25 am |
Thanks for your fast and efficient reply |
