Interrupt handling
unni.anad
Interrupt handling
PostPosted: Fri Aug 14, 2009 9:49 am     Reply with quote
Whether ccs compiler itself take care of saving the W-REG and STATUS reg during when it serves an interrupt routine. In an example code provided it is shown as to be done by the programmer. (given in ALP).
  #asm
   //store current state of processor
   MOVWF save_w
   SWAPF status,W
   BCF   status,5
   BCF   status,6
   MOVWF save_status
   // Save anything else your code may change
   // You need to do something with PCLATH if you have GOTOs
   // remember to check to see what interrupt fired if using more than one!!
   // code for isr
   BCF   t0if
   INCF  counter,F
   BTFSC zero_flag
   INCF  (&counter+1),F
   // restore processor and return from interrupt
   SWAPF save_status,W
   MOVWF status
   SWAPF save_w,F
   SWAPF save_w,W
   #endasm
In an another example using C
#INT_TIMER2 //HIGH
void timer2_isr()
   count++;
What is the difference ?
PostPosted: Fri Aug 14, 2009 11:14 am     Reply with quote
See this thread for a detailed explanation of the CCS interrupt handler code:
http://www.ccsinfo.com/forum/viewtopic.php?t=29173
unni.anad
PostPosted: Fri Aug 14, 2009 11:25 am     Reply with quote
Thanks for your fast and efficient reply
