ccs_guest Guest
multiplication and div. |
Posted: Thu Jul 30, 2009 11:38 pm |
Hi all,
Consider the following scenario.
int32 tmp1;
float a;
tmp1=-33862;
a=(float)tmp1/1000000000;
The value in a should be should be -0.00003386 but a=4.294934.
If I do
then a=4.000000
What is wrong?
Thnx... |
Posted: Fri Jul 31, 2009 12:20 am |
Quote: | int32 tmp1;
float a;
tmp1=-33862; |
In CCS, all integer data types are unsigned by default. To declare tmp1
as signed, you need to do this:
ccs_guest Guest
Posted: Fri Jul 31, 2009 12:44 am |
After making tmp as signed, a is having -0.00000; |
Posted: Fri Jul 31, 2009 12:50 am |
Which 'a' ? The first one, or the 2nd one ?
The first expression is doing floating point math, and the 2nd one is
doing integer math.
Always make a test program and always post it (along with your compiler
version). The program shown below displays the following results:
Quote: |
a = -0.000033862
a = 0.000000000
Code: | #include <16F877.H>
signed int32 tmp1;
float a;
tmp1=-33862;
a=((float)tmp1)/1000000000.0;
printf("a = %10.9f \r", a);
a=tmp1/1000000000;
Posted: Fri Jul 31, 2009 12:57 am |
That solved my problem.
Thanks a lot. |
