LED not blinking....
sanddune008
PostPosted: Mon Jul 20, 2009 8:43 am     Reply with quote
#include <16F877.h>
#device adc=8
//#FUSES XT
#FUSES HS
#FUSES NOLVP                      //Low Voltage Programming on B3(PIC16) or B5(PIC18)
//#FUSES NOCPD                    //No EE protection
//#FUSES NOWRT                    //Program memory not write protected
//#FUSES NODEBUG                  //No Debug mode for ICD
#use fast_io(A)
#use delay(clock=11000000)
#use i2c(Master,Fast,sda=PIN_C4,scl=PIN_C3)
/***        Macro Definitions                                             ***/
// Standard definitions
#define RED_LED         PIN_A0    // (output) Red LED (low true)
// Macros to simplify I/O operations
#define RED_LED_ON      output_low(RED_LED)
#define RED_LED_OFF     output_high(RED_LED)
   RED_LED_ON;
   setup_adc_ports(NO_ANALOGS);
   setup_adc(ADC_OFF);
   setup_psp(PSP_DISABLED);
   setup_timer_1(T1_DISABLED);
     RED_LED_ON;
     delay_us(500);
     RED_LED_OFF;
     delay_us(500);
I am using 11.0592 Mhz crystal....
don't know whats wrong with the following code...
qseeker
PostPosted: Mon Jul 20, 2009 8:52 am     Reply with quote
Delete #use fast_io(A) or use set_tris_a()
PostPosted: Mon Jul 20, 2009 8:53 am     Reply with quote
#use fast_io(a).....
I you select this, it becomes _your_ responsibility to set TRIS. You are not doing this.
Either remove this line, or set the TRIS register for port A.
sanddune008
PostPosted: Mon Jul 20, 2009 9:22 am     Reply with quote
i removed fast_io().....now the LED has come up.....but its steady and not blinking....
I am using 11.05932Mhz......
qseeker
PostPosted: Mon Jul 20, 2009 9:34 am     Reply with quote
delay_us(500) is too fast.... try delay_ms(500)
sanddune008
PostPosted: Mon Jul 20, 2009 9:42 am     Reply with quote
thanks.....i didn't notice the micro second thing....
