sanddune008
LED not blinking.... |
Posted: Mon Jul 20, 2009 8:43 am |
Code: | #include <16F877.h>
#device adc=8
//#FUSES XT
#FUSES HS
#FUSES NOLVP //Low Voltage Programming on B3(PIC16) or B5(PIC18)
//#FUSES NOCPD //No EE protection
//#FUSES NOWRT //Program memory not write protected
//#FUSES NODEBUG //No Debug mode for ICD
#use fast_io(A)
#use delay(clock=11000000)
#use i2c(Master,Fast,sda=PIN_C4,scl=PIN_C3)
/*** Macro Definitions ***/
// Standard definitions
#define RED_LED PIN_A0 // (output) Red LED (low true)
// Macros to simplify I/O operations
#define RED_LED_ON output_low(RED_LED)
#define RED_LED_OFF output_high(RED_LED)
RED_LED_ON;
setup_adc_ports(NO_ANALOGS);
setup_adc(ADC_OFF);
setup_psp(PSP_DISABLED);
setup_timer_1(T1_DISABLED);
RED_LED_ON;
delay_us(500);
RED_LED_OFF;
delay_us(500);
I am using 11.0592 Mhz crystal....
don't know whats wrong with the following code... |
qseeker
Posted: Mon Jul 20, 2009 8:52 am |
Delete #use fast_io(A) or use set_tris_a() |
Posted: Mon Jul 20, 2009 8:53 am |
#use fast_io(a).....
I you select this, it becomes _your_ responsibility to set TRIS. You are not doing this.
Either remove this line, or set the TRIS register for port A.
sanddune008
Posted: Mon Jul 20, 2009 9:22 am |
i removed fast_io().....now the LED has come up.....but its steady and not blinking....
I am using 11.05932Mhz...... |
qseeker
Posted: Mon Jul 20, 2009 9:34 am |
delay_us(500) is too fast.... try delay_ms(500) |
sanddune008
Posted: Mon Jul 20, 2009 9:42 am |
thanks.....i didn't notice the micro second thing.... |
