ok thank you I understood my problem. Working with PIC which has GPIO port must describe this port as:
set_tris_a(XX);
Posted: Sun Jul 19, 2009 10:47 am
You don't have to do that. You can let the compiler set the TRIS for you.
It will set the TRIS automatically if you use the CCS functions, such as
output_low(), output_high(), etc. Example:
http://www.ccsinfo.com/forum/viewtopic.php?t=38261
