How can I work with PIC12f683?
theasus
PostPosted: Sat Jul 18, 2009 7:15 am     Reply with quote
How can I adjust input and output of this PIC12F683?(GPIO)
Also I want to control The PWM unit. Could you send me sample code?
PostPosted: Sat Jul 18, 2009 2:25 pm     Reply with quote
Here is a PWM example for the 12F683:
http://www.ccsinfo.com/forum/viewtopic.php?t=39468&start=11
PostPosted: Sun Jul 19, 2009 10:34 am     Reply with quote
ok thank you I understood my problem. Working with PIC which has GPIO port must describe this port as:
set_tris_a(XX);
PostPosted: Sun Jul 19, 2009 10:47 am     Reply with quote
You don't have to do that. You can let the compiler set the TRIS for you.
It will set the TRIS automatically if you use the CCS functions, such as
output_low(), output_high(), etc. Example:
http://www.ccsinfo.com/forum/viewtopic.php?t=38261
