BobbyDD Guest
Problem with Nokia 3310 |
Posted: Mon May 19, 2008 2:54 pm |
i use a Pic18F452 and the Nokia 3310 display with the sample from www.techdesign.be/projects/012/012.htm
My problem is, that all char. from the table5 are not shown correct on the display. I use to compile the CCS 4.025 an i cant find the problem.
Can anyone help me, please??
many greetings
Bobby
ps: sorry for my bad english.
Here my code:
#define nok_sclk PIN_D5
#define nok_sda PIN_D4
#define nok_dc PIN_C5
#define nok_cs PIN_D3
#define nok_res PIN_D2
char char_row,charsel,charpos,chardata; // for nokia_3310 lcd
int16 ddram;
char plot_value;
int32 plot_value32;
int32 plot_umsb,plot_lmsb,plot_ulsb,plot_llsb;
BYTE const TABLE5[240]= {0x00,0x00,0x00,0x00,0x00, // 20 space ASCII table for NOKIA LCD: 96 rows * 5 bytes= 480 bytes
0x00,0x00,0x5f,0x00,0x00, // 21 !
0x00,0x07,0x00,0x07,0x00, // 22 "
0x14,0x7f,0x14,0x7f,0x14, // 23 #
0x24,0x2a,0x7f,0x2a,0x12, // 24 $
0x23,0x13,0x08,0x64,0x62, // 25 %
0x36,0x49,0x55,0x22,0x50, // 26 &
0x00,0x05,0x03,0x00,0x00, // 27 '
0x00,0x1c,0x22,0x41,0x00, // 28 (
0x00,0x41,0x22,0x1c,0x00, // 29 )
0x14,0x08,0x3e,0x08,0x14, // 2a *
0x08,0x08,0x3e,0x08,0x08, // 2b +
0x00,0x50,0x30,0x00,0x00, // 2c ,
0x08,0x08,0x08,0x08,0x08, // 2d -
0x00,0x60,0x60,0x00,0x00, // 2e .
0x20,0x10,0x08,0x04,0x02, // 2f /
0x3e,0x51,0x49,0x45,0x3e, // 30 0
0x00,0x42,0x7f,0x40,0x00, // 31 1
0x42,0x61,0x51,0x49,0x46, // 32 2
0x21,0x41,0x45,0x4b,0x31, // 33 3
0x18,0x14,0x12,0x7f,0x10, // 34 4
0x27,0x45,0x45,0x45,0x39, // 35 5
0x3c,0x4a,0x49,0x49,0x30, // 36 6
0x01,0x71,0x09,0x05,0x03, // 37 7
0x36,0x49,0x49,0x49,0x36, // 38 8
0x06,0x49,0x49,0x29,0x1e, // 39 9
0x00,0x36,0x36,0x00,0x00, // 3a :
0x00,0x56,0x36,0x00,0x00, // 3b ;
0x08,0x14,0x22,0x41,0x00, // 3c <
0x14,0x14,0x14,0x14,0x14, // 3d =
0x00,0x41,0x22,0x14,0x08, // 3e >
0x02,0x01,0x51,0x09,0x06, // 3f ?
0x32,0x49,0x79,0x41,0x3e, // 40 @
0x7e,0x11,0x11,0x11,0x7e, // 41 A
0x7f,0x49,0x49,0x49,0x36, // 42 B
0x3e,0x41,0x41,0x41,0x22, // 43 C
0x7f,0x41,0x41,0x22,0x1c, // 44 D
0x7f,0x49,0x49,0x49,0x41, // 45 E
0x7f,0x09,0x09,0x09,0x01, // 46 F
0x3e,0x41,0x49,0x49,0x7a, // 47 G
0x7f,0x08,0x08,0x08,0x7f, // 48 H
0x00,0x41,0x7f,0x41,0x00, // 49 I
0x20,0x40,0x41,0x3f,0x01, // 4a J
0x7f,0x08,0x14,0x22,0x41, // 4b K
0x7f,0x40,0x40,0x40,0x40, // 4c L
0x7f,0x02,0x0c,0x02,0x7f, // 4d M
0x7f,0x04,0x08,0x10,0x7f, // 4e N
0x3e,0x41,0x41,0x41,0x3e // 4f O
BYTE const TABLE6[240]= {0x7f,0x09,0x09,0x09,0x06, // 50 P
0x3e,0x41,0x51,0x21,0x5e, // 51 Q
0x7f,0x09,0x19,0x29,0x46, // 52 R
0x46,0x49,0x49,0x49,0x31, // 53 S
0x01,0x01,0x7f,0x01,0x01, // 54 T
0x3f,0x40,0x40,0x40,0x3f, // 55 U
0x1f,0x20,0x40,0x20,0x1f, // 56 V
0x3f,0x40,0x38,0x40,0x3f, // 57 W
0x63,0x14,0x08,0x14,0x63, // 58 X
0x07,0x08,0x70,0x08,0x07, // 59 Y
0x61,0x51,0x49,0x45,0x43, // 5a Z
0x00,0x7f,0x41,0x41,0x00, // 5b [
0x02,0x04,0x08,0x10,0x20, // 5c
0x00,0x41,0x41,0x7f,0x00, // 5d
0x04,0x02,0x01,0x02,0x04, // 5e
0x40,0x40,0x40,0x40,0x40, // 5f
0x00,0x01,0x02,0x04,0x00, // 60
0x20,0x54,0x54,0x54,0x78, // 61 a
0x7f,0x48,0x44,0x44,0x38, // 62 b
0x38,0x44,0x44,0x44,0x20, // 63 c
0x38,0x44,0x44,0x48,0x7f, // 64 d
0x38,0x54,0x54,0x54,0x18, // 65 e
0x08,0x7e,0x09,0x01,0x02, // 66 f
0x0c,0x52,0x52,0x52,0x3e, // 67 g
0x7f,0x08,0x04,0x04,0x78, // 68 h
0x00,0x44,0x7d,0x40,0x00, // 69 i
0x20,0x40,0x44,0x3d,0x00, // 6a j
0x7f,0x10,0x28,0x44,0x00, // 6b k
0x00,0x41,0x7f,0x40,0x00, // 6c l
0x7c,0x04,0x18,0x04,0x78, // 6d m
0x7c,0x08,0x04,0x04,0x78, // 6e n
0x38,0x44,0x44,0x44,0x38, // 6f o
0x7c,0x14,0x14,0x14,0x08, // 70 p
0x08,0x14,0x14,0x18,0x7c, // 71 q
0x7c,0x08,0x04,0x04,0x08, // 72 r
0x48,0x54,0x54,0x54,0x20, // 73 s
0x04,0x3f,0x44,0x40,0x20, // 74 t
0x3c,0x40,0x40,0x20,0x7c, // 75 u
0x1c,0x20,0x40,0x20,0x1c, // 76 v
0x3c,0x40,0x30,0x40,0x3c, // 77 w
0x44,0x28,0x10,0x28,0x44, // 78 x
0x0c,0x50,0x50,0x50,0x3c, // 79 y
0x44,0x64,0x54,0x4c,0x44, // 7a z
0x00,0x08,0x36,0x41,0x00, // 7b
0x00,0x00,0x7f,0x00,0x00, // 7c
0x00,0x41,0x36,0x08,0x00, // 7d
0x10,0x08,0x08,0x10,0x08, // 7e
0x78,0x46,0x41,0x46,0x78 // 7f
void nokia_init(void);
void nokia_write_command(char bytefornokia_command);
void nokia_write_data(char bytefornokia_data);
void nokia_write_dorc(char bytefornokia);
void nokia_gotoxy(int8 xnokia, int8 ynokia);
void nokia_erase_y(int8 ynokia);
void nokia_erase_x(int8 xnokia);
void nokia_printchar(int8 cvar);
void nokia_clean_ddram(void);
void table_to_nokialcd(void);
void nokia_plot(int8 xnokia,int8 plot_value8);
void nokia_write_data_inv(char bytefornokia_data_inv);
void nokia_clear_screen(void);
void nokia_clear_xy(int8 xnokia, int8 ynokia);
void nokia_print_uparrow(void);
void nokia_print_downarrow(void);
void nokia_print_leftarrow(void);
void nokia_print_rightarrow(void);
void nokia_print_degree(void);
void nokia_print_lowbatdegree(void);
output_high(nok_dc); // bytes are stored in the display data ram, address counter, incremented automatically
output_high(nok_cs); // chip disabled
output_low(nok_res); // reset chip during 250ms
delay_ms(10); // works with less.....
output_high(nok_res);
nokia_write_command(0x21); // set extins extended instruction set
nokia_write_command(0xc2); // Vop v1: 0xc8 (for 3V)// v2: 0xa0 (for 3V) // v3: 0xc2 (2v6-5v) ********************************************************************************************************************
nokia_write_command(0x13); // bias
nokia_write_command(0x20); // horizontal mode from left to right, X axe are incremented automatically , 0x22 for vertical addressing ,back on normal instruction set too
nokia_write_command(0x09); // all on
nokia_clean_ddram(); // reset DDRAM, otherwise the lcd is blurred with random pixels
nokia_write_command(0x08); // mod control blank change (all off)
nokia_write_command(0x0c); // mod control normal change
nokia_gotoxy(0,0); // 84*6=504 clear LCD
for (ddram=504;ddram>0;ddram--){nokia_write_data(0x00);}
output_low(nok_dc); // byte is a command it is read with the eight SCLK pulse
output_low(nok_cs); // chip enabled
nokia_write_dorc(bytefornokia_command);
nokia_write_dorc(bytefornokia_data);
void nokia_write_dorc(char bytefornokia) // serial write data or command subroutine
char caa;
for (caa=8;caa>0;caa--) {
output_low(nok_sclk);
// delay_us(2);
if ((bytefornokia&0x80)==0){output_low(nok_sda);}
else {output_high(nok_sda);}
output_high(nok_sclk);
bytefornokia=bytefornokia<<1;
void nokia_gotoxy(int8 xnokia, int8 ynokia) // Nokia LCD 3310 Position cursor
nokia_write_command(0x40|(ynokia&0x07)); // Y axe initialisation: 0100 0yyy
nokia_write_command(0x80|(xnokia&0x7f)); // X axe initialisation: 1xxx xxxx
nokia_gotoxy(0,ynokia);
printf(nokia_printchar," ");
char column;
for (column=0;column!=6;column++){
nokia_gotoxy(xnokia,column);
void nokia_printchar(int8 cvar) // Write 1 character to LCD
charsel=cvar;
table_to_nokialcd();
void table_to_nokialcd(void) // extract ascii from tables & write to LCD
if (charsel<0x20)return;
if (charsel>0x7f)return;
for (char_row=0;char_row<5;char_row++) { // 5 bytes
if (charsel<0x50){charpos=(((charsel&0xff)-0x20)*5);chardata=TABLE5[(charpos+char_row)];} // use TABLE5
else if (charsel>0x4f){charpos=(((charsel&0xff)-0x50)*5);chardata=TABLE6[(charpos+char_row)];} // use TABLE6
nokia_write_data(chardata); // send data to nokia
nokia_write_data(0x00); // 1 byte (always blank)
char i;
plot_value32=0;
// plot_value32|=1; // unremark this if you want dotgraph instead of bargraph
for (i=0;i!=plot_value8;i++){
plot_value32|=1; // remark this if you want dotgraph instead of bargraph
plot_value32<<=1;
plot_value32|=2; // bottom line is always filled
plot_llsb=(plot_value32&0xff);
plot_ulsb=((plot_value32>>8)&0xff);
plot_lmsb=((plot_value32>>16)&0xff);
plot_umsb=((plot_value32>>24)&0xff);
nokia_gotoxy(xnokia,1);
nokia_write_data_inv(plot_umsb);
nokia_gotoxy(xnokia,2);
nokia_write_data_inv(plot_lmsb);
nokia_gotoxy(xnokia,3);
nokia_write_data_inv(plot_ulsb);
nokia_gotoxy(xnokia,4);
nokia_write_data_inv(plot_llsb);
char caa;
delay_us(2);
if ((bytefornokia_data_inv&0x01)==0){output_low(nok_sda);}
bytefornokia_data_inv=bytefornokia_data_inv>>1;
nokia_erase_y(0);
nokia_erase_y(1);
nokia_erase_y(2);
nokia_erase_y(3);
nokia_erase_y(4);
nokia_erase_y(5);
nokia_gotoxy(xnokia,ynokia);
nokia_printchar(" ");
nokia_write_data(0x04);
nokia_write_data(0x02);
nokia_write_data(0x7f);
nokia_write_data(0x10);
nokia_write_data(0x20);
nokia_write_data(0x08);
nokia_write_data(0x1c);
nokia_write_data(0x2a);
nokia_write_data(0xf8);
nokia_write_data(0x06);
nokia_write_data(0x09);
// nokia_printchar(" ");
nokia_write_data(0x0f);
and the main-part:
#include "C:\Pic\test4\test4.h"
#include "C:\Pic\test4\lcd.c"
setup_adc_ports(NO_ANALOGS);
setup_adc(ADC_OFF);
setup_psp(PSP_DISABLED);
setup_spi(FALSE);
setup_wdt(WDT_OFF);
setup_timer_0(RTCC_INTERNAL);
setup_timer_1(T1_DISABLED);
setup_oscillator(False);
SET_TRIS_C(0x9f); // iooi iiii
SET_TRIS_D(0x02); // oooo ooio
nokia_init();
nokia_gotoxy(0,0);
printf(nokia_printchar,"Hallo Bobby");
Rohit de Sa
Posted: Sat Jul 04, 2009 10:23 am |
I'm having a funny sort of problem. I'm using a '628 with Michel Bavin's driver (the one above). The 3310 is on PORT B:
nok_sclk - B1
nok_sda - B2
nok_dc - B3
nok_cs - B4
nok_res - B5
I'm providing power to the LCD from A0, through two 4148 diodes (to drop the voltage to the acceptable ~3.3v).I've checked the voltage at the LCD's Vcc. It's about 3.2v. I've also connected the clock, data and other pins through 1k resistors to prevent frying the PCD8544 driver chip.
I've used the example code given in the driver
Code: | nokia_init();
nokia_gotoxy(0,0);
printf(nokia_printchar,"test???"); |
I've also used this Code: | while(1)
output_toggle(pin_a1);
} | with an LED at the end of the code as a sort of 'checkpoint'. The code seems fine to me, and the LED flashes away merrily, but I see nothing on the display.
Now the funny part - the LCD works fine through my parallel port using LCDInfo. Occasionally, the LCD fails to display anything. But even then, when I exit LCDInfo, a horizontal line pops up on the LCD for a fraction of a second showing me that the LCD is still working.
I've been trying to get the LCD working for quite some time now, and I'm kinda stumped. Suggestions? Advice? Help?
Rohit |
Rohit de Sa
Posted: Sat Jul 04, 2009 10:26 am |
Another thing - in the 'Absolute Maximum Ratings' section of the the PCD8544 datasheet, it says that Vdd can be a maximum of 7v. Does this mean I can run the LCD at PIC voltages (ie 5v)? Or is there a reason I must go through the drop diode/resistor ritual?
Rohit |
Joan
Joined: 29 May 2004 Posts: 41 Location: Barcelona, Spain
Posted: Tue Sep 01, 2009 4:06 am |
Quote: | Does this mean I can run the LCD at PIC voltages (ie 5v)? |
Yes, it can. But nominal values are 3V3.
Regards,
Joan _________________ I Came. I Saw. I Won. |
