This code need some serious rewriting. Couple of years I wrote similar program for the 16F84A in the assembly.
At the first glimpse your frequency is not 40kHz. I suppose that you use 40kHz ultrasound transmiter/receiver pair. Your code transmits at ~ 8,7kHz.
Here is the flow how you should do this:
Init the PIC
Send ping (8 pulses at 40kHz) <---------+
Set timer1 to 0 |
Delay (see comment *) |
Check if pong received <--------+ |
+----- NO --------------+ |
Calculate distance from time |
Display distance |
* Delay is used because first reply is not the correct one. Determine that based on experience.
aasief
Posted: Thu Apr 30, 2009 5:06 am
Thanx for ur response.
The delays I'm using are correct because I get 38.7 kHz out. I don't know why I do because looking at it, the PIC isn't doing what it's supposed to be doing.
I'm having a problem with capturing the pulse. I am getting a received pulse and I measured it and I get the correct time delay for distance measured.
I suspect that whatever is making my delays not work, is the same thing that's making my capture not work. Is there something wrong with my void isr loop ?
