ultrasonic range finder
aasief
PostPosted: Wed Apr 29, 2009 6:22 am     Reply with quote
Could someone tell me whats wrong with this code
#include "16f877.h"
#define use_portb_lcd
#include "lcd.c"
#int_ccp1
unsigned int time;
{   int x;
    output_low(pin_a5);
    setup_ccp1(ccp_capture_re);
    setup_timer_1(t1_internal);
    for(x=0;x<5;x++)
   output_high(pin_d2);
   delay_us(90);
   output_low(pin_d2);
   delay_us(25);
   delay_us(1000);
    output_high(pin_a5);
    enable_interrupts(global);
    enable_interrupts(int_ccp1);
    delay_ms(60);
void isr_ccp1()
   time=ccp_1;
   printf(lcd_putc"t=%5u  ",time);
   set_timer1(0);
   clear_interrupt(int_ccp1);
bungee-
PostPosted: Wed Apr 29, 2009 7:43 am     Reply with quote
This code need some serious rewriting. Couple of years I wrote similar program for the 16F84A in the assembly.
At the first glimpse your frequency is not 40kHz. I suppose that you use 40kHz ultrasound transmiter/receiver pair. Your code transmits at ~ 8,7kHz.
Here is the flow how you should do this:
           Init the PIC
       Send ping (8 pulses at 40kHz) <---------+
          Set timer1 to 0                      |
        Delay (see comment *)                  |
        Check if pong received <--------+      |
                +----- NO --------------+      |
        Calculate distance from time           |
          Display distance                     |
* Delay is used because first reply is not the correct one. Determine that based on experience.
aasief
PostPosted: Thu Apr 30, 2009 5:06 am     Reply with quote
Thanx for ur response.
The delays I'm using are correct because I get 38.7 kHz out. I don't know why I do because looking at it, the PIC isn't doing what it's supposed to be doing.
I'm having a problem with capturing the pulse. I am getting a received pulse and I measured it and I get the correct time delay for distance measured.
I suspect that whatever is making my delays not work, is the same thing that's making my capture not work. Is there something wrong with my void isr loop ?
Thanx
