Problem with CCS "expecting an identifier"
chongado
PostPosted: Sat Apr 25, 2009 1:35 am     Reply with quote
Hi there,
I got a problem with error "expecting an identifier"
at this line --> static void DoWrite(void); in my code
I don't understand, Could you help me Sir?
Thank you. Wink
PostPosted: Sat Apr 25, 2009 5:12 am     Reply with quote
The error isn't in this line. It's either appearing in the wrong place, or there is a syntax error before.
chongado
Thank you
PostPosted: Sat Apr 25, 2009 5:35 am     Reply with quote
Thank you, I'll check the code before this line.
PostPosted: Sat Apr 25, 2009 9:22 am     Reply with quote
Look further back if there is still nothing obvious.
This is an at times 'unfortunate' feature of CCS, where it will quite often give an error quite a few lines 'after' the actual problem. The compiler keeps 'trudging through' the lines, till a perfectly normal line fails, because it reads it in a completely 'wrong' way....
chongado
PostPosted: Sat Apr 25, 2009 11:24 am     Reply with quote
Umm.. ok I got it. ^^
chongado
Still have problem
PostPosted: Sat Apr 25, 2009 11:35 am     Reply with quote
Hi Sir. I'll post my source for you.
#define XEE_SUCCESS FALSE
#define EEPROM_BUFFER_SIZE   (32)
typedef BOOL XEE_RESULT;
typedef unsigned long  DWORD;
void DoWrite(void);
void XEEInit(void);
XEE_RESULT XEEBeginWrite(DWORD address);
XEE_RESULT XEEWrite(BYTE val);
XEE_RESULT XEEEndWrite(void);
XEE_RESULT XEEBeginRead(DWORD address);
BYTE XEERead(void);
XEE_RESULT XEEReadArray(DWORD address, BYTE *buffer, BYTE length);
XEE_RESULT XEEEndRead(void);
BOOLEAN XEEIsBusy(void);
static DWORD EEPROMAddress;
static BYTE  EEPROMBuffer[EEPROM_BUFFER_SIZE];
static BYTE *EEPROMBufferPtr;
This is all source code in a file of my project and I still have old problem.
chongado
Hi haha!!
PostPosted: Sat Apr 25, 2009 11:46 am     Reply with quote
I found something when I comment some code
void DoWrite(void);
void XEEInit(void);
BYTE XEERead(void);
the old error disappear!!!!
How can I define something like the code that I comment it?
Thank you.^^
chongado
Huh! I've got a new error
PostPosted: Sat Apr 25, 2009 12:54 pm     Reply with quote
the error is "Identifier is already used in this scope"
How can I do? Sir.
PostPosted: Sat Apr 25, 2009 1:10 pm     Reply with quote
I can't see, how the code should compile when commenting the said part.
The problem is actually with BOOL, that is neither a standard C nor a CCS specific type identifier (Though it's defined with many PC compilers). Simply provide a definition like
#define BOOL int1
bungee-
Re: Hi haha!!
PostPosted: Sat Apr 25, 2009 1:12 pm     Reply with quote
try like that:
typedef int1 XEE_RESULT;
It is possible that DWORD is allready defined. Try to use another identifier.
chongado
reply
PostPosted: Sat Apr 25, 2009 11:08 pm     Reply with quote
#define BOOL int1
Hi Sir. In a header file that I include in my .c file, It's define a BOOL like this "typedef int1 BOOL" (this include file is before I use "typedef BOOL XEE_RESULT")
chongado
Hi This is my Project please help me to compile success
PostPosted: Sun Apr 26, 2009 12:00 am     Reply with quote
http://www.uploadd.com/download.aspx?pku=3A517B174BF45U[RUKNMSCN2EWQ1D6
please help me Crying or Very sad
bungee-
PostPosted: Sun Apr 26, 2009 6:54 am     Reply with quote
You are trying to combine files for different compilers. This will not work. You need to rewrite the complete SPIEEPROM to be compatible with CCS compiler.
asmboy
BTW: ALL
PostPosted: Sun Apr 26, 2009 12:57 pm     Reply with quote
for those wondering:
STATIC and BOOL syntax both belong in the ( personally observed to be ) gawd_awful BAAD SOURCEBOOST ( alleged ) compiler universe.
That brings one closer to the dark little the heart of where the trouble is with this code as posted.
I was early on a victim of that pretty horrible mess o'compiler myself.
Never going back tho.
I would urge that a complete rewrite be done, utilizing CCS intrinsics, before the next attempt to compile.
