Problem with CCS "expecting an identifier"
chongado
PostPosted: Sat Apr 25, 2009 1:35 am     Reply with quote
Hi there,
I got a problem with error "expecting an identifier"
at this line --> static void DoWrite(void); in my code
I don't understand, Could you help me Sir?
Thank you. Wink
FvM
PostPosted: Sat Apr 25, 2009 5:12 am     Reply with quote
The error isn't in this line. It's either appearing in the wrong place, or there is a syntax error before.
chongado
Thank you
PostPosted: Sat Apr 25, 2009 5:35 am     Reply with quote
Thank you, I'll check the code before this line.
PostPosted: Sat Apr 25, 2009 9:22 am     Reply with quote
Look further back if there is still nothing obvious.
This is an at times 'unfortunate' feature of CCS, where it will quite often give an error quite a few lines 'after' the actual problem. The compiler keeps 'trudging through' the lines, till a perfectly normal line fails, because it reads it in a completely 'wrong' way....
chongado
PostPosted: Sat Apr 25, 2009 11:24 am     Reply with quote
Umm.. ok I got it. ^^
chongado
Still have problem
PostPosted: Sat Apr 25, 2009 11:35 am     Reply with quote
Hi Sir. I'll post my source for you.
#define XEE_SUCCESS FALSE
#define EEPROM_BUFFER_SIZE   (32)
typedef BOOL XEE_RESULT;
typedef unsigned long  DWORD;
void DoWrite(void);
void XEEInit(void);
XEE_RESULT XEEBeginWrite(DWORD address);
XEE_RESULT XEEWrite(BYTE val);
XEE_RESULT XEEEndWrite(void);
XEE_RESULT XEEBeginRead(DWORD address);
BYTE XEERead(void);
XEE_RESULT XEEReadArray(DWORD address, BYTE *buffer, BYTE length);
XEE_RESULT XEEEndRead(void);
BOOLEAN XEEIsBusy(void);
static DWORD EEPROMAddress;
static BYTE  EEPROMBuffer[EEPROM_BUFFER_SIZE];
static BYTE *EEPROMBufferPtr;
This is all source code in a file of my project and I still have old problem.
chongado
Hi haha!!
PostPosted: Sat Apr 25, 2009 11:46 am     Reply with quote
I found something when I comment some code
void DoWrite(void);
void XEEInit(void);
BYTE XEERead(void);
the old error disappear!!!!
How can I define something like the code that I comment it?
Thank you.^^
chongado
Huh! I've got a new error
PostPosted: Sat Apr 25, 2009 12:54 pm     Reply with quote
the error is "Identifier is already used in this scope"
How can I do? Sir.
FvM
PostPosted: Sat Apr 25, 2009 1:10 pm     Reply with quote
I can't see, how the code should compile when commenting the said part.
The problem is actually with BOOL, that is neither a standard C nor a CCS specific type identifier (Though it's defined with many PC compilers). Simply provide a definition like
#define BOOL int1
bungee-
Re: Hi haha!!
PostPosted: Sat Apr 25, 2009 1:12 pm     Reply with quote
try like that:
typedef int1 XEE_RESULT;
It is possible that DWORD is allready defined. Try to use another identifier.
chongado
reply
PostPosted: Sat Apr 25, 2009 11:08 pm     Reply with quote
#define BOOL int1
Hi Sir. In a header file that I include in my .c file, It's define a BOOL like this "typedef int1 BOOL" (this include file is before I use "typedef BOOL XEE_RESULT")
chongado
Hi This is my Project please help me to compile success
PostPosted: Sun Apr 26, 2009 12:00 am     Reply with quote
http://www.uploadd.com/download.aspx?pku=3A517B174BF45U[RUKNMSCN2EWQ1D6
please help me Crying or Very sad
bungee-
PostPosted: Sun Apr 26, 2009 6:54 am     Reply with quote
You are trying to combine files for different compilers. This will not work. You need to rewrite the complete SPIEEPROM to be compatible with CCS compiler.
BTW: ALL
PostPosted: Sun Apr 26, 2009 12:57 pm     Reply with quote
for those wondering:
STATIC and BOOL syntax both belong in the ( personally observed to be ) gawd_awful BAAD SOURCEBOOST ( alleged ) compiler universe.
That brings one closer to the dark little the heart of where the trouble is with this code as posted.
I was early on a victim of that pretty horrible mess o'compiler myself.
Never going back tho.
I would urge that a complete rewrite be done, utilizing CCS intrinsics, before the next attempt to compile.
