I would like to take an 8 bit binary number, and separate the 8 bits into an array of size 8.
Can anyone help me with this?
I do know C a bit, but am not familiar with CCS.
Thank you!
Here is what I had started:
BYTE array[8]
void main(void){
int mynum = 0b00010101;
for int i =0; i<8; i++){
array[i] =
I just wasn't sure if I should somehow truncate mynum of if there is an easier way to separate this BYTE.
Thanks for any help with this fairly simple C question...
deperkin
Array in CCS cont.
Posted: Fri Mar 13, 2009 2:18 pm
maybe to clarify...
what i really would like to do is take in an analog signal...
seperate it, then send have of the lower byte to a nibble on one port and the other half of the lower byte to a nibble on another port.
THanks!!
Sydney
Posted: Fri Mar 13, 2009 2:19 pm
BYTE array[8]
void main(void){
array[i] = mynum & 1;
mynum >>= 1;
