Array in CCS
deperkin
Array in CCS
PostPosted: Fri Mar 13, 2009 2:04 pm     Reply with quote
I would like to take an 8 bit binary number, and separate the 8 bits into an array of size 8.
Can anyone help me with this?
I do know C a bit, but am not familiar with CCS.
Thank you!
Here is what I had started:
BYTE array[8]
void main(void){
int mynum = 0b00010101;
for int i =0; i<8; i++){
array[i] =
I just wasn't sure if I should somehow truncate mynum of if there is an easier way to separate this BYTE.
Thanks for any help with this fairly simple C question...
deperkin
Array in CCS cont.
PostPosted: Fri Mar 13, 2009 2:18 pm     Reply with quote
maybe to clarify...
what i really would like to do is take in an analog signal...
seperate it, then send have of the lower byte to a nibble on one port and the other half of the lower byte to a nibble on another port.
THanks!!
Sydney
PostPosted: Fri Mar 13, 2009 2:19 pm     Reply with quote
BYTE array[8]
void main(void){
array[i] = mynum & 1;
mynum >>= 1;
Would be a destructive way.
PostPosted: Fri Mar 13, 2009 2:25 pm     Reply with quote
See the integer to binary conversion routine in this post:
http://www.ccsinfo.com/forum/viewtopic.php?t=1523&start=1
Two more routines:
http://www.ccsinfo.com/forum/viewtopic.php?t=37877
deperkin
PostPosted: Fri Mar 13, 2009 2:36 pm     Reply with quote
Kudos to you both!
this is a big help.
BR
