How Select Device in CCS?
pablodecker
PostPosted: Fri Mar 13, 2009 6:53 am     Reply with quote
someone knows how is the code in CCS to select device in MPLAB?
PostPosted: Fri Mar 13, 2009 12:22 pm     Reply with quote
See this page on using CCS with MPLAB:
http://www.ccsinfo.com/faq.php?page=ccs_mplab
pablodecker
PostPosted: Fri Mar 13, 2009 12:37 pm     Reply with quote
Thank for your answer!!!, but i need to write a line code where select the device for then program with ICD2.
For example, i change the device for other by Configure -> Select Device
Then, i'll like that when i compile my project, change the device that is written in my project...
PostPosted: Fri Mar 13, 2009 1:16 pm     Reply with quote
Change the #include line at the top of your program.
If you were using the 16F877, like this:
#include <16F877.h>
And you want to change to an 18F452, then change it to this:
#include <18F452.h>
pablodecker
PostPosted: Fri Mar 13, 2009 1:20 pm     Reply with quote
#include <16F877.h>
#include <18F452.h>
Thanks, but this not change the device in MPLAB (you can look this in the bottom of MPLAB)...
Thanks!
PostPosted: Fri Mar 13, 2009 1:22 pm     Reply with quote
Then go to the Configure menu in MPLAB and select the PIC from the
drop-down box. That's how you do it. You must change the device in
those two places: In your code and in MPLAB.
That's the only way it can be done.
pablodecker
PostPosted: Fri Mar 13, 2009 1:26 pm     Reply with quote
Thanks, i do them, but i'll automatize them, see that this can't
Thanks for your help!!!
