I2C HELP
GLADKIH
I2C HELP
PostPosted: Thu Feb 19, 2009 12:15 pm     Reply with quote
hello from UKRAINE.
master
i2c_start();
i2c_write(ADRES+1);
prom=i2c_read(0);
i2c_stop();
slave
#int_SSP
VOID SSP_isr()
signed long long int prom;
state = i2c_isr_state();
if (state>=128)
      prom=170;
      i2c_write(prom);
Why at a parcel(sending) master of this code slave two times come into interruption. First time after exhibiting the address and second time after exhibiting stop. Thus if I put if (state > =128) that the master hangs. And if if (state == 128) that all is normal. Unless on stop there should be an interruption??. And still as to me to organize the program slave if the master transfers the following
i2c_start ();
i2c_write (ADRES+1);
prom=i2c_read (0);
prom=i2c_read (0);
prom=i2c_read (0);
i2c_stop ();
It is the text I translate(transport) by the interpreter therefore excuse for rough translation.
PostPosted: Thu Feb 19, 2009 6:40 pm     Reply with quote
Use the CCS example file code, Ex_Slave.c, for the Slave PIC.
It's in this directory:
c:\Program Files\picc\Examples\Ex_Slave.c
Use the code in this post for the Master PIC:
http://www.ccsinfo.com/forum/viewtopic.php?t=32368&start=3
This will show how to write and read a byte between the master PIC
and the slave PIC with i2c.
Make sure that you have pull-up resistors on the SDA and SCL lines.
You can use 4.7K (4700 ohms) resistors.
