#int_SSP
VOID SSP_isr()
signed long long int prom;
state = i2c_isr_state();
if (state>=128)
prom=170;
i2c_write(prom);
Why at a parcel(sending) master of this code slave two times come into interruption. First time after exhibiting the address and second time after exhibiting stop. Thus if I put if (state > =128) that the master hangs. And if if (state == 128) that all is normal. Unless on stop there should be an interruption??. And still as to me to organize the program slave if the master transfers the following
