asmboy
an oddity with ones complement or TTWIW? |
Posted: Mon Jan 19, 2009 9:38 am |
PCM ver 4.066
the ones complement seems odd - or perhaps its me
for the following simple case
unsigned int8 myvar=7;
myvar=~myvar; // generates COMF assembler as desired
~myvar; //
// and
~~myvar; // generates NEITHER an error NOR the desired COMF opcode
// NO code produced at in the LST file for either form
// meanwhile
myvar~; // and
myvar~~; // both generate an error 'expecting ;'
is it ME or the compiler ??? |
Posted: Mon Jan 19, 2009 12:32 pm |
It wouldn't. You are not putting the result into a variable, so the optimiser removes the lines...
It is a bit like saying:
myval+1;
Again no code will be generated.
asmboy
Posted: Tue Jan 20, 2009 9:26 am |
sorry - i guess i was stuck under the impression that 1's complementing was a unitary operation in the exact same category as ++var or --var, which don't need a reassignment to work - since there is an underlying assembler, single cycle opcode for it .
That and the lack of an error when i try ~~var .
i guess you are maybe saying TTWIW is the real answer, since there is no reason a compiler couldn't be made to recognize ~~ and treat it like ++, -- etc. |
SherpaDoug
Posted: Tue Jan 20, 2009 12:49 pm |
What would you expect ~~var to do? Would it be the same as ~(~var) which would do nothing?
++ and -- have clear meanings, but ~~ is not clear to me. _________________ The search for better is endless. Instead simply find very good and get the job done. |
Posted: Tue Jan 20, 2009 3:06 pm |
Vs. 4.066 generates a warning. You need to enable warnings.
Quote: | >>> Warning 207 "pcm_test.c" Line 12(1,1): Code has no effect |
MSVC 6.0 generates a similar warning if you try a similar program with it:
Quote: | warning C4552: '~' : operator has no effect; |
Test program:
Code: | #include <16F877.h>
#fuses XT, NOWDT, BROWNOUT, PUT, NOLVP
#use delay(clock=8000000)
int8 value;
~value;
