Take a look ...weird problem |
Posted: Wed Jan 14, 2009 8:38 am |
Hello guys !
I'm encountering a strange problem with a otherwise straight forward program. If i'm no mistaken, when 10 ms have passed, pin B0 should go high. Right ?? .... NOPE....NOT HAPPENING !!
Why is that ? Any ideas ?
I'm using CCS C version 4.057.
Here is the code :
#include <18F452.h>
char gc_TEST_timer;
#define TEST_TIMER_TICKS 1
#define RTCC_PRELOAD 217
#INT_RTCC
void rtcc_isr(void)
set_rtcc(RTCC_PRELOAD);
if (gc_TEST_timer)
gc_TEST_timer--;
void check_TIMER(void)
if (gc_TEST_timer)
return;
gc_TEST_timer= TEST_TIMER_TICKS;
output_high(pin_b0);
gc_TEST_TIMER=TEST_TIMER_TICKS;
setup_counters(RTCC_INTERNAL, RTCC_DIV_256);
enable_interrupts(INT_RTCC);
check_timer();
Cheers !!
Vasi |
Posted: Wed Jan 14, 2009 9:18 am |
Timer0.
Clocking off 4000000/(256*4) = 3906.25Hz
Max count 65535 wrapping back to 0 - total 65536 - remember default is 16bit mode.
Total count time = 16.7 seconds.....
Posted: Wed Jan 14, 2009 9:55 am |
Ahhhhh...thank you Ttelmah ...yes, the timer0 is 16 bit default.
Sorry about this stupid question! I wasn't paying atention ! ![Embarassed](images/smiles/icon_redface.gif) |
Posted: Wed Jan 14, 2009 10:14 am |
Here is the CORRECT code ( thank you again Ttelmah) !
The folowing code applyes in relation to PCM Programer's multitasking program (tank you also, PCM Programer):
#include <18F452.h>
char gc_TEST_timer;
#INT_RTCC
void rtcc_isr(void)
if (gc_TEST_timer)
gc_TEST_timer--;
if (gc_TEST_timer)
return;
setup_timer_0(RTCC_INTERNAL|RTCC_DIV_256|RTCC_8_BIT);
set_timer0(RTCC_PRELOAD);
check_timer();
| [/code] |
Posted: Wed Jan 14, 2009 10:23 am |
Anyone here, who 'claims' never to have had a moment like this, is lying....
This particular one, is common for people who are used to the 16 chips, where timer0, is only 8bit.
Same program - different problem |
Posted: Thu Jan 15, 2009 12:32 am |
Hello Ttelmah !
I've got another issue with this code.
One of my tasks is to receive a character over serial and transform it into binary form.
However, the function that returns the character, bgetc(), isn't used properly in the check_SERIAL() function.
If my C knowledge is correct, is should have worked !!
Here is the code in question:
#int_rda
void serial_isr() {
int t;
output_toggle(pin_b1); //debug
buffer[next_in]=getc();
t=next_in;
if(next_in==next_out)
next_in=t; // Buffer full !!
BYTE bgetc() {
BYTE c;
output_toggle(pin_b2); // debug
while(!bkbhit) ;
c=buffer[next_out];
return(c);
void check_SERIAL( void)
char i,d;
if(gc_IRTRANSMIT_timer)
output_toggle(pin_b3);
return;
gc_IRTRANSMIT_timer = IRTRANSMIT_TIMER_TICKS;
output_toggle(pin_b4); //debug
for(i = 0; i < 8; i++)
output_toggle(pin_b5); //debug
if( bgetc() & 0x80)
d='1';
d='0';
bgetc() <<= 1;
cmd[i]=d;
cmd[8]=0;
output_toggle(pin_b6); //debug
printf("%s",cmd);
Any ideas/hints ?? |
Posted: Thu Jan 15, 2009 12:33 am |
P.S.: I'm using PIC18f452 @ 10 MHZ and CCS C version 4.057
Thank You !! |
Posted: Thu Jan 15, 2009 12:37 am |
I've tried another solution.
In the original post, PCM Programmer said the following things :
Quote: |
// Check the interrupt-driven software fifo here,
// to see if any characters are in the buffer.
// If so, handle them. See EX_SISR.C for
// an example of how to do the software fifo.
// Make the size of the fifo be large enough,
// so that it doesn't overflow between the
// times that you come into this task to check it.
// Or, set the gc_IRTRANSMIT_timer value to a lower
// value, so that you check the fifo sufficiently often.
// Once you've read the characters, then put
// code here to act on them. If it's a command
// sent through the serial port, then set a global
// flag. Then, one of the other tasks can read
// the flag and it can do something -- perhaps
// it could start a complex sequence of LED blinking.
// (It would also clear the global flag).
So...i've tried the code in the following way :
void check_IRTRANSMIT( void)
char c,i,d;
return;
while(!bkbhit) ;
c=buffer[next_out];
if( c & 0x80)
d='1';
d='0';
c <<= 1;
cmd[i]=d;
cmd[8]=0;
printf("%s",cmd);
Still no succes ...... HMMMM
Please help me !!!!!!!! |
Wayne_
Posted: Thu Jan 15, 2009 3:21 am |
You were close
char c,i,d;
return;
// Does it definately get here ?
c = bgetc(); // Need to get 1 8bit value, use bgetc
if( c & 0x80)
d='1';
d='0';
c <<= 1;
cmd[i]=d;
cmd[8]=0; // I assume cmd is defined as char cmd[9];
printf("%s",cmd); // What DOES it output ?
If you read my comments you will notice you have missed a few vital bits of info to help us debug this.
Change c = bgetc(); to c = 0xAA; and see if you get 10101010
Chage to different values and see if you get the correct value.
If bgetc does not work but c=n; does then the problem lies with your serial routines/interface.
Try
c = bgetc();
printf("%c", c);
to see exactly what it is.
Also put printf("Start\r\n");
at the start of your code to make sure your serial output works. |
Posted: Thu Jan 15, 2009 4:15 am |
Hello Wayne_ !
HUH ....A stupid mistake was the cause of this error. I've forgotten to enable the RDA interrupt.
Ufffffffffffffffffff..... Thank you Wayne_ ! I've noticed this when i was trying to copy the program to post it here. ![Laughing](images/smiles/icon_lol.gif) |
