Take a look ...weird problem
PostPosted: Wed Jan 14, 2009 8:38 am     Reply with quote
Hello guys !
I'm encountering a strange problem with a otherwise straight forward program. If i'm no mistaken, when 10 ms have passed, pin B0 should go high. Right ?? .... NOPE....NOT HAPPENING !!
Why is that ? Any ideas ?
I'm using CCS C version 4.057.
Here is the code :
#include <18F452.h>
char gc_TEST_timer;
#define TEST_TIMER_TICKS   1
#define RTCC_PRELOAD 217
#INT_RTCC
void rtcc_isr(void)
         set_rtcc(RTCC_PRELOAD);
           if (gc_TEST_timer)
              gc_TEST_timer--;
void check_TIMER(void)
           if (gc_TEST_timer)
                 return;
            gc_TEST_timer= TEST_TIMER_TICKS;
            output_high(pin_b0);
  gc_TEST_TIMER=TEST_TIMER_TICKS;
  setup_counters(RTCC_INTERNAL, RTCC_DIV_256);
  enable_interrupts(INT_RTCC);
check_timer();
Cheers !!
Vasi
PostPosted: Wed Jan 14, 2009 9:18 am     Reply with quote
Timer0.
Clocking off 4000000/(256*4) = 3906.25Hz
Max count 65535 wrapping back to 0 - total 65536 - remember default is 16bit mode.
Total count time = 16.7 seconds.....
PostPosted: Wed Jan 14, 2009 9:55 am     Reply with quote
Ahhhhh...thank you Ttelmah ...yes, the timer0 is 16 bit default.
Sorry about this stupid question! I wasn't paying atention ! Embarassed
PostPosted: Wed Jan 14, 2009 10:14 am     Reply with quote
Here is the CORRECT code ( thank you again Ttelmah) !
The folowing code applyes in relation to PCM Programer's multitasking program (tank you also, PCM Programer):
#include <18F452.h>
char gc_TEST_timer;
#INT_RTCC
void rtcc_isr(void)
 if (gc_TEST_timer)
     gc_TEST_timer--;
   if (gc_TEST_timer)
      return;
  setup_timer_0(RTCC_INTERNAL|RTCC_DIV_256|RTCC_8_BIT);
  set_timer0(RTCC_PRELOAD);
check_timer();
[/code]
PostPosted: Wed Jan 14, 2009 10:23 am     Reply with quote
Anyone here, who 'claims' never to have had a moment like this, is lying....
Smile
This particular one, is common for people who are used to the 16 chips, where timer0, is only 8bit.
Same program - different problem
PostPosted: Thu Jan 15, 2009 12:32 am     Reply with quote
Hello Ttelmah !
I've got another issue with this code.
One of my tasks is to receive a character over serial and transform it into binary form.
However, the function that returns the character, bgetc(), isn't used properly in the check_SERIAL() function.
If my C knowledge is correct, is should have worked !! Rolling Eyes
Here is the code in question:
#int_rda
void serial_isr() {
   int t;
   output_toggle(pin_b1);   //debug
   buffer[next_in]=getc();
   t=next_in;
   if(next_in==next_out)
     next_in=t;           // Buffer full !!
BYTE bgetc() {
   BYTE c;
   output_toggle(pin_b2); // debug
   while(!bkbhit) ;
   c=buffer[next_out];
   return(c);
void check_SERIAL( void)
char i,d;
if(gc_IRTRANSMIT_timer)
   output_toggle(pin_b3);
   return;
   gc_IRTRANSMIT_timer  = IRTRANSMIT_TIMER_TICKS;
   output_toggle(pin_b4);  //debug
    for(i = 0; i < 8; i++)
             output_toggle(pin_b5); //debug
             if( bgetc() & 0x80)
               d='1';
               d='0';
              bgetc() <<= 1;
               cmd[i]=d;
        cmd[8]=0;
       output_toggle(pin_b6); //debug
            printf("%s",cmd);
Any ideas/hints ??
PostPosted: Thu Jan 15, 2009 12:33 am     Reply with quote
P.S.: I'm using PIC18f452 @ 10 MHZ and CCS C version 4.057
Thank You !!
PostPosted: Thu Jan 15, 2009 12:37 am     Reply with quote
I've tried another solution.
In the original post, PCM Programmer said the following things :
// Check the interrupt-driven software fifo here,
// to see if any characters are in the buffer.
// If so, handle them. See EX_SISR.C for
// an example of how to do the software fifo.
// Make the size of the fifo be large enough,
// so that it doesn't overflow between the
// times that you come into this task to check it.
// Or, set the gc_IRTRANSMIT_timer value to a lower
// value, so that you check the fifo sufficiently often.
// Once you've read the characters, then put
// code here to act on them. If it's a command
// sent through the serial port, then set a global
// flag. Then, one of the other tasks can read
// the flag and it can do something -- perhaps
// it could start a complex sequence of LED blinking.
// (It would also clear the global flag).
So...i've tried the code in the following way :
void check_IRTRANSMIT( void)
char c,i,d;
   return;
   while(!bkbhit) ;
   c=buffer[next_out];
             if( c & 0x80)
               d='1';
               d='0';
              c <<= 1;
               cmd[i]=d;
        cmd[8]=0;
            printf("%s",cmd);
Still no succes ...... HMMMM
Please help me !!!!!!!!
Wayne_
PostPosted: Thu Jan 15, 2009 3:21 am     Reply with quote
You were close
char c,i,d;
   return;
   // Does it definately get here ?
   c = bgetc();  // Need to get 1 8bit value, use bgetc
             if( c & 0x80)
               d='1';
               d='0';
              c <<= 1;
               cmd[i]=d;
        cmd[8]=0;  // I assume cmd is defined as char cmd[9];
            printf("%s",cmd);  // What DOES it output ?
If you read my comments you will notice you have missed a few vital bits of info to help us debug this.
Change c = bgetc(); to c = 0xAA; and see if you get 10101010
Chage to different values and see if you get the correct value.
If bgetc does not work but c=n; does then the problem lies with your serial routines/interface.
Try
c = bgetc();
printf("%c", c);
to see exactly what it is.
Also put printf("Start\r\n");
at the start of your code to make sure your serial output works.
PostPosted: Thu Jan 15, 2009 4:15 am     Reply with quote
Hello Wayne_ !
HUH ....A stupid mistake was the cause of this error. I've forgotten to enable the RDA interrupt.
Ufffffffffffffffffff..... Thank you Wayne_ ! I've noticed this when i was trying to copy the program to post it here. Laughing
