Newbie problem about locate instruction
pandorassbox
PostPosted: Sat Dec 20, 2008 7:59 am     Reply with quote
I want to prevent c from using 30000 Byte area. How can I do this? Can I do this by using locate instruction?
dyeatman
PostPosted: Sat Dec 20, 2008 8:11 am     Reply with quote
I think #RESERVE is what you want.
PostPosted: Sun Dec 21, 2008 3:35 pm     Reply with quote
If you're referring to Flash memory, then use the #org command to
reserve a block of memory. From the CCS manual:
#org start, end {}
See this thread for an example:
http://www.ccsinfo.com/forum/viewtopic.php?t=35480&highlight=org
