desertkids
store string & adc reference help!!! |
Posted: Wed Dec 03, 2008 9:49 am |
hi, now I'm working for my final year project. i need to measure 2 temperature sensor and 1 pressure sensor and transmit the value measured through MU-1-R transceiver. i have write some code for this project. now i face 2 problem, first is for pressure sensor, because the range of pressure I'm going to measure are very small (from 99kPa to 101kPa) and the voltage output also very small (range from 4.11V to 4.17V), so i hope can measure the 0.001V change from pressure sensor, this should be can done by 12bit adc, but my pic18f4550 cant make 12bit adc. so can i measure pressure sensor with voltage reference but measure temperature sensor for 0-5V?(see my code)or can suggest better opinion?
My second problem is how I can store the string into buffer? Lets say I have 20 loop of data. For first data I store at buffer 1, second data store at buffer and so on.
Maybe my explanation not so detail, but I can explain more if need. Please help me, thanks.
#include <18F4550.h>
#device ADC=10 // define 10 bit resolution
#use rs232(baud=19200, xmit=PIN_C6, rcv=PIN_C7, parity=n, bits=8, BRGH1OK, stream=UART)
#use rs232(baud=4800, xmit=PIN_D0, rcv=PIN_D1, parity=n, bits=8, BRGH1OK, stream=GPS)
#include <stdlib.h>
#define buzzer pin_b0
#define sw1 pin_b1
#define temp1_ch 0
#define temp2_ch 1
#define press_ch 4
#define acc_x_ch 5
#define acc_y_ch 6
#define acc_z_ch 7
signed int temp_1,temp_2;
float volt_temp_1, volt_temp_2, volt_press,press,;
int n;
float analog_read(int channel);
set_tris_a(0xff);
set_tris_b(0xff);
for(n=1;n<21;n++)
//setup_adc_ports(AN0_TO_AN7|VREF_VREF);
//setup_adc(ADC_CLOCK_DIV_64);
volt_temp_1= analog_read(temp1_ch);
temp_1=((float)volt_temp_1-2.73)*100;
//setup_adc_ports(AN0_TO_AN7);
volt_temp_2= analog_read(temp2_ch);
temp_2=((float)volt_temp_1-2.73)*100;
volt_press=analog_read(press_ch);
press=(((float)volt_press-0.204)*21.7865)+15;
fprintf(UART,"\r\ntransmitting...");
fprintf(UART,"\r\n%2d,%1.3f,%3.2f,%1.2f,%d,%1.2f,%d",n,volt_press,press,volt_temp_1,temp_1,volt_temp_2,temp_2);
//store the string in buffer[n](n from 1 to 20)
//sprintf(buff[n],"\r\n%2d,%1.3f,%3.2f,%1.2f,%d,%1.2f,%d",n,volt_press,press,volt_temp_1,temp_1,volt_temp_2,temp_2);
printf("\r\nFINISH TRANS!!!");
delay_ms(2000);
//how to print the string that store in buffer 1 to buffer 20 to uart
//for(n=1;n<21;n++)
//fprintf(UART,buff[n]);
fprintf(UART,"\r\nFINISH ALL!!!");
float analog_read(int channel){
float tmp = 0;
set_adc_channel(channel); // select channel
delay_ms(10);
tmp = read_adc(); // read into volt reg
return (float)tmp/204.6; //(a/(5/1023))
Rohit de Sa
Posted: Wed Dec 03, 2008 10:34 am |
Quote: | but measure temperature sensor for 0-5V | You haven't mentioned the kind of temperature sensor you are using (thermistor, LM35, etc), but since you are using an ADC, I assume it is one of these (or equivalent). Thermistor-based sensors have a non-linear output, while for LM35 sensors the voltage output is linear. For the thermistor you can use a data-table which stores voltage-temperature information, and for the LM35 use a voltage-slope-offset approach.
Quote: | voltage output also very small (range from 4.11V to 4.17V), so i hope can measure the 0.001V change from pressure sensor | The only option is to amplify the voltage. Buffer the signal; use a reference of 4.11 volts (or thereabouts) and a gain of approximately ( 5 / (max_value-min_value) ). You may need an instrumentation amplifier and some additional hardware for this.
Quote: | how i can store the string into buffer | Use an array for this. Code: | float volt_temp_1[20] | In the loop Code: | for(n=0;n<20;n++) [corrected, can believe how I messed that up :oops: ] | use Code: | volt_temp_1[n]=analog_read(temp1_ch); |
A few other things:
Use the 'code' BBCode tags when you post code. It's much more readable that way.
The 'set_tris()' instruction is redundant. The CCS compile handles all direction setting for you automatically (unless you use the directive '#use fast_io()'.
Uncomment the 'setup_adc' instruction. Put it outside the loop. You need just one of these instructions through the entire program.
Rohit
asmallri
Posted: Wed Dec 03, 2008 10:56 am |
Rohit de Sa wrote: | Quote: |
Quote: | voltage output also very small (range from 4.11V to 4.17V), so i hope can measure the 0.001V change from pressure sensor | The only option is to amplify the voltage. Buffer the signal; use a reference of 4.11 volts (or thereabouts) and a gain of approximately ( 5 / (max_value-min_value) ). You may need an instrumentation amplifier and some additional hardware for this. |
This is not quite correct. You need to level shift the input voltage and apply gain. Here is a link which talks about the basics: http://www.daycounter.com/Circuits/OpAmp-Level-Shifter/OpAmp-Level-Shifter.phtml
In your case you want the output of the opamp to center around 2.5 volts (for a 5V VDD) with a gain of 5. _________________ Regards, Andrew
Rohit de Sa
Posted: Wed Dec 03, 2008 10:47 pm |
Quote: | use a reference of 4.11 volts (or thereabouts) and a gain of approximately ( 5 / (max_value-min_value) ) |
Quote: | You need to level shift the input voltage and apply gain | I meant exactly that. Sorry, I should have been a little clearer and more technically correct. My fault.
Rohit |
crystal_lattice
Posted: Thu Dec 04, 2008 2:02 am |
your code for the loop is wrong, you will not use the full array size and it will overflow. Use:
for(n=0;n<20;n++)
This will give you a range from 0-19, which is valid for the array you declared. |
