store string & adc reference help!!!
desertkids
PostPosted: Wed Dec 03, 2008 9:49 am     Reply with quote
hi, now I'm working for my final year project. i need to measure 2 temperature sensor and 1 pressure sensor and transmit the value measured through MU-1-R transceiver. i have write some code for this project. now i face 2 problem, first is for pressure sensor, because the range of pressure I'm going to measure are very small (from 99kPa to 101kPa) and the voltage output also very small (range from 4.11V to 4.17V), so i hope can measure the 0.001V change from pressure sensor, this should be can done by 12bit adc, but my pic18f4550 cant make 12bit adc. so can i measure pressure sensor with voltage reference but measure temperature sensor for 0-5V?(see my code)or can suggest better opinion?
My second problem is how I can store the string into buffer? Lets say I have 20 loop of data. For first data I store at buffer 1, second data store at buffer and so on.
Maybe my explanation not so detail, but I can explain more if need. Please help me, thanks.
#include <18F4550.h>
#device ADC=10 // define 10 bit resolution
#use rs232(baud=19200, xmit=PIN_C6, rcv=PIN_C7, parity=n, bits=8, BRGH1OK, stream=UART)
#use rs232(baud=4800, xmit=PIN_D0, rcv=PIN_D1, parity=n, bits=8, BRGH1OK, stream=GPS)
#include <stdlib.h>
#define buzzer pin_b0
#define sw1 pin_b1
#define temp1_ch 0
#define temp2_ch 1
#define press_ch 4
#define acc_x_ch 5
#define acc_y_ch 6
#define acc_z_ch 7
signed int temp_1,temp_2;
float volt_temp_1, volt_temp_2, volt_press,press,;
int n;
float analog_read(int channel);
set_tris_a(0xff);
set_tris_b(0xff);
for(n=1;n<21;n++)
//setup_adc_ports(AN0_TO_AN7|VREF_VREF);
//setup_adc(ADC_CLOCK_DIV_64);
volt_temp_1= analog_read(temp1_ch);
temp_1=((float)volt_temp_1-2.73)*100;
//setup_adc_ports(AN0_TO_AN7);
volt_temp_2= analog_read(temp2_ch);
temp_2=((float)volt_temp_1-2.73)*100;
volt_press=analog_read(press_ch);
press=(((float)volt_press-0.204)*21.7865)+15;
fprintf(UART,"\r\ntransmitting...");
fprintf(UART,"\r\n%2d,%1.3f,%3.2f,%1.2f,%d,%1.2f,%d",n,volt_press,press,volt_temp_1,temp_1,volt_temp_2,temp_2);
//store the string in buffer[n](n from 1 to 20)
//sprintf(buff[n],"\r\n%2d,%1.3f,%3.2f,%1.2f,%d,%1.2f,%d",n,volt_press,press,volt_temp_1,temp_1,volt_temp_2,temp_2);
printf("\r\nFINISH TRANS!!!");
delay_ms(2000);
//how to print the string that store in buffer 1 to buffer 20 to uart
//for(n=1;n<21;n++)
//fprintf(UART,buff[n]);
fprintf(UART,"\r\nFINISH ALL!!!");
float analog_read(int channel){
float tmp = 0;
set_adc_channel(channel); // select channel
delay_ms(10);
tmp = read_adc(); // read into volt reg
return (float)tmp/204.6; //(a/(5/1023))
Rohit de Sa
PostPosted: Wed Dec 03, 2008 10:34 am     Reply with quote
You haven't mentioned the kind of temperature sensor you are using (thermistor, LM35, etc), but since you are using an ADC, I assume it is one of these (or equivalent). Thermistor-based sensors have a non-linear output, while for LM35 sensors the voltage output is linear. For the thermistor you can use a data-table which stores voltage-temperature information, and for the LM35 use a voltage-slope-offset approach.
The only option is to amplify the voltage. Buffer the signal; use a reference of 4.11 volts (or thereabouts) and a gain of approximately ( 5 / (max_value-min_value) ). You may need an instrumentation amplifier and some additional hardware for this.
how i can store the string into buffer
Use an array for this.
float volt_temp_1[20]
In the loop
for(n=0;n<20;n++)   [corrected, can believe how I messed that up :oops: ]
use
volt_temp_1[n]=analog_read(temp1_ch);
A few other things:
Use the 'code' BBCode tags when you post code. It's much more readable that way.
The 'set_tris()' instruction is redundant. The CCS compile handles all direction setting for you automatically (unless you use the directive '#use fast_io()'.
Uncomment the 'setup_adc' instruction. Put it outside the loop. You need just one of these instructions through the entire program.
Rohit
asmallri
PostPosted: Wed Dec 03, 2008 10:56 am     Reply with quote
Rohit de Sa wrote:
This is not quite correct. You need to level shift the input voltage and apply gain. Here is a link which talks about the basics: http://www.daycounter.com/Circuits/OpAmp-Level-Shifter/OpAmp-Level-Shifter.phtml
In your case you want the output of the opamp to center around 2.5 volts (for a 5V VDD) with a gain of 5.
Regards, Andrew
Rohit de Sa
PostPosted: Wed Dec 03, 2008 10:47 pm     Reply with quote
I meant exactly that. Sorry, I should have been a little clearer and more technically correct. My fault.
Rohit
crystal_lattice
PostPosted: Thu Dec 04, 2008 2:02 am     Reply with quote
your code for the loop is wrong, you will not use the full array size and it will overflow. Use:
for(n=0;n<20;n++)
This will give you a range from 0-19, which is valid for the array you declared.
