RS232 and an LED
IceMetal
RS232 and an LED
PostPosted: Thu Nov 20, 2008 7:46 pm     Reply with quote
I'm trying to turn an LED with the serial port and get a confirmation but some how my code doesn't work, what am I doing wrong?
#include <16F887.h>             // header file for the PIC16F887
                                // includes built-in functions and constants
                                // for arguments/returns.
#FUSES NOWDT               //No Watch Dog Timer
#FUSES NOMCLR
#FUSES NOCPD
#FUSES NOBROWNOUT            //No brown out, so the pic will work under 4.0V
#FUSES XT
void main() {
  while(TRUE){
if ('a' == getc()) output_high(PIN_D0);
printf("led on\r\n");
else output_low(PIN_D0);
printf("led off\r\n");
MarcosAmbrose
PostPosted: Thu Nov 20, 2008 8:26 pm     Reply with quote
Try this
      if(kbhit())
         if(getc()=='a')
            output_low(PIN_D0);
Also, when you're posting code use the "Code" tags to preserve your codes formating. Makes it easier to read.
