IceMetal
Joined: 20 Nov 2008 Posts: 79 Location: white Plains, NY
RS232 and an LED |
Posted: Thu Nov 20, 2008 7:46 pm |
I'm trying to turn an LED with the serial port and get a confirmation but some how my code doesn't work, what am I doing wrong?
#include <16F887.h> // header file for the PIC16F887
// includes built-in functions and constants
// for arguments/returns.
#FUSES NOMCLR
#FUSES NOCPD
#FUSES NOBROWNOUT //No brown out, so the pic will work under 4.0V
#FUSES XT
while(TRUE){
if ('a' == getc()) output_high(PIN_D0);
printf("led on\r\n");
else output_low(PIN_D0);
printf("led off\r\n");
MarcosAmbrose
Joined: 25 Sep 2006 Posts: 38 Location: Adelaide, Australia
Posted: Thu Nov 20, 2008 8:26 pm |
Try this
if(kbhit())
if(getc()=='a')
output_low(PIN_D0);
Also, when you're posting code use the "Code" tags to preserve your codes formating. Makes it easier to read. |
