nurquhar
Joined: 05 Aug 2006 Posts: 149 Location: Redditch, UK
A better terminal prog than SIOW ! |
Posted: Mon Nov 10, 2008 3:59 am |
I just came across this terminal program after having some frustration with Siow sometimes displaying some characters as 'blanks' until a CR is received.
It seems to be shareware and works in similar way to Siow, ie there's a window for the input and another for output. It has a lot more features than Siow and is ideal for serial port debugging etc.
If the link don't work do a search for "Terminal Br@y++".
Enjoy......
http://braypp.googlepages.com/terminal |
Rocket
Posted: Tue Nov 11, 2008 1:29 pm |
The program I find most useful is, http://www.docklight.de
It really works well for what I do, I just need to figure out how to use it with the CCS bootloader.
SHALOM! _________________ J.I.L. |
Posted: Tue Nov 11, 2008 3:25 pm |
I really like realterm. Seems to be much more configurable than hyperterminal. You can change any setting without having to start a new connection. You can also choose a wide variety of display options for data. You can create shortcuts that will open the program configured to your preferred settings, as well. My favorite feature is the indicators that flash if you are connected, or if data is being sent or received. |
nurquhar
Posted: Tue Nov 11, 2008 3:37 pm |
See before you try !!
![](http://braypp.googlepages.com/terminal.png/terminal-medium;init:.jpg) |
dbotkin
Joined: 08 Sep 2003 Posts: 197 Location: Omaha NE USA
Posted: Tue Nov 11, 2008 3:42 pm |
For general use -- when you don't need to see hex codes and stuff, but HyperTerminal just sucks too bad to use -- I like PuTTY. Also does telnet, ssh, etc. |
