A better terminal prog than SIOW !
nurquhar
PostPosted: Mon Nov 10, 2008 3:59 am     Reply with quote
I just came across this terminal program after having some frustration with Siow sometimes displaying some characters as 'blanks' until a CR is received.
It seems to be shareware and works in similar way to Siow, ie there's a window for the input and another for output. It has a lot more features than Siow and is ideal for serial port debugging etc.
If the link don't work do a search for "Terminal Br@y++".
Enjoy......
http://braypp.googlepages.com/terminal
Rocket
PostPosted: Tue Nov 11, 2008 1:29 pm     Reply with quote
The program I find most useful is, http://www.docklight.de
It really works well for what I do, I just need to figure out how to use it with the CCS bootloader.
SHALOM!
J.I.L.
PostPosted: Tue Nov 11, 2008 3:25 pm     Reply with quote
I really like realterm. Seems to be much more configurable than hyperterminal. You can change any setting without having to start a new connection. You can also choose a wide variety of display options for data. You can create shortcuts that will open the program configured to your preferred settings, as well. My favorite feature is the indicators that flash if you are connected, or if data is being sent or received.
nurquhar
PostPosted: Tue Nov 11, 2008 3:37 pm     Reply with quote
See before you try !! Wink
dbotkin
PostPosted: Tue Nov 11, 2008 3:42 pm     Reply with quote
For general use -- when you don't need to see hex codes and stuff, but HyperTerminal just sucks too bad to use -- I like PuTTY. Also does telnet, ssh, etc.
