Bill_Smith
Joined: 06 Feb 2004 Posts: 26 Location: Curitiba, Brazil
| HOW TO PATCH pic18_usb.h TO WORK WITH PIC18F4553s |
Posted: Wed Oct 29, 2008 3:34 pm |
| Does anyone know what to patch in the pic18_usb.h driver to allow it to compile on the PIC18F4553? The onboard USB module should be pretty much the same as the PIC18F4550. |
FvM
Posted: Wed Oct 29, 2008 4:48 pm |
Yes, this should be the case according to the datasheet.
You can include the respective device name in the lines before
#define __USB_4550__ |
Bill_Smith
| PATCH TO ALLOW PIC18F4553 TO WORK WITH CCS |
Posted: Thu Oct 30, 2008 5:09 am |
Vielen Dank fuer die helfe Fvm!
Here are the changes to the file. Just cut and replace before line 424 in the pic18_usb.h file. I placed comments at each modification.
//// pic18_usb.c ////
//// Hardware layer for CCS's USB library. This hardware layer ////
//// supports the USB peripheral on the PIC18 family chips. Current ////
//// supported families are: ////
//// PIC18F2455/2550/4455/4550/4553 ////
//// PIC18F2450/4450 ////
//// PIC18F65J50/66J50/66J55/67J50/85J50/86J50/86J55/87J50 ////
//// This file is part of CCS's PIC USB driver code, which includes: ////
//// usb_desc_*.h - an example set of config and device descriptor ////
//// usb.c - USB token and request handler code ////
//// usb.h - definitions, prototypes and global variables ////
//// The following examples are provided by CCS: ////
//// ex_usb_mouse.c - A HID Mouse. ////
//// ex_usb_hid.c - A custom application using HID protocol. ////
//// ex_usb_kbmouse.c - A HID Mouse/Keyboard combo using multiple ////
//// interfaces. ////
//// ex_usb_kbmouse2.c - A HID Mouse/Keyboard combo using multiple ////
//// HID Reports. ////
//// ex_usb_scope.c - A digital oscilloscope using a custom ////
//// protocol requiring custom Windows drivers. ////
//// ex_usb_serial.c - ////
//// ex_usb_serial2.c - Two examples of using the CDC driver for ////
//// a virtual COM port. ////
//// *********** NOTE ABOUT 18F2450/4450 LIMITATIONS ********** ////
//// Due to the limited USB RAM of this family, a limitation of ////
//// this driver is that there are only 3 endpoints (0, 1 and 2). ////
//// The HW actually supports more endpoints, but to simplify ////
//// driver development this driver will only support the first 3 ////
//// so there is an easier memory block to work with. ////
//// USB_MAX_EP0_PACKET_LENGTH will also be set to 8 regardless ////
//// of USB speed, to save RAM. ////
//// ************** NOTE ABOUT HW REQUIREMENTS **************** ////
//// If you are not using internal pullups, you will need to put ////
//// an internal pullup resistor on C4 or C5 depending on if you ////
//// want to use slow speed or full speed. This code configures ////
//// the device to use internal pullups, see usb_init() if you ////
//// want to change that. ////
//// You need approximately 470nF cap on C3, even if you are using ////
//// the internal 3.3V USB regulator. ////
//// To run at full speed, you must use the oscillator ////
//// configuration (PLLx) to set the PLL divide to 4MHz. You can ////
//// configure the MCU clock to any speed (up to 48MHz) but the ////
//// PLL must run at 4Mhz to provide the USB peripheral with a ////
//// 96MHz clock. See the datasheet for details. ////
//// To run at slow speed you must configure your MCU to run at ////
//// 24Mhz. See the datasheet for details. ////
//// **************** NOTE ABOUT INTERRUPTS ****************** ////
//// This driver uses INT_USB. It requires INT_USB to interrupt the ////
//// PIC when an event has happened on the USB Bus. Therfore ////
//// this code enables interrupts. A user modification can be made ////
//// to poll the USB interrupt flag instead of relying on an ////
//// interrupt. ////
//// **************** USER FUNCTIONS *********************** ////
//// usb_init() - Initializes the USB stack, the USB peripheral and ////
//// attaches the unit to the usb bus. Enables ////
//// interrupts. ////
//// usb_init_cs() - A smaller usb_init(), does not attach unit ////
//// to usb bus or enable interrupts. ////
//// usb_put_packet() - Sends one packet to the host. ////
//// If you need to send a message that spans ////
//// more than one packet then see usb_puts() in ////
//// usb.c ////
//// usb_kbhit() - Returns true if OUT endpoint contains data from ////
//// host. ////
//// usb_rx_packet_size() - Returns the size of packet that was ////
//// received. usb_kbhit() must return TRUE else ////
//// this is not valid. Don't forget in USB there ////
//// are 0 len packets! ////
//// usb_get_packet() - Gets one packet that from the host. ////
//// usb_kbhit() must return true before you call ////
//// this routine or your data may not be valid. ////
//// Once usb_kbhit() returns true you want to ////
//// call this as soon as possible to get data ////
//// out of the endpoint buffer so the PC can ////
//// start sending more data, if needed. ////
//// This only receives one packet, if you are ////
//// trying to receive a multi-packet message ////
//// see usb_gets() in usb.c. ////
//// usb_detach() - De-attach USB from the system. ////
//// usb_attach() - Attach USB to the system. ////
//// usb_attached() - Returns TRUE if the device is attached to a ////
//// USB cable. A macro that looks at the defined ////
//// connection sense pin. ////
//// usb_task() - Keeps track of connection sense, calling ////
//// usb_detach() and usb_attach() when needed. ////
//// For more documentation on these functions read the comments at ////
//// each function. ////
//// The other functions defined in this file are for use by the ////
//// USB code, and is not meant to be used by the user. ////
//// Version History: ////
//// 10-30-08: Patched to work with PIC18F4553 (wrs) ////
//// 09-19-07: Fixed problems with 18F4450 family. ////
//// 07-17-07: Added 18F4450,2450 support ////
//// 07-13-07: Added 87J50 family support ////
//// 11-01-05: usb_detach(), usb_attach() and usb_init_cs() ////
//// changed for the better. ////
//// 10-28-05: Added usb_rx_packet_size() ////
//// 07-13-05: usb_put_packet() changed for 16bit packet sizes ////
//// usb_flush_in() changed for 16bit packet sizes ////
//// usb_get_packet() changed for 16bit packet sizes ////
//// usb_flush_out() changed for 16bit packet sizes ////
//// usb_set_configured() changed for 16bit packet sizes ////
//// 06-30-05: usb_tbe() added ////
//// The way endpoint 0 DTS is set has been changed. ////
//// 06-20-05: Initial Release ////
//// 05-13-05: Beta Release (Full Speed works) ////
//// 03-21-05: Initial Alpha Release ////
//// (C) Copyright 1996,2005 Custom Computer Services ////
//// This source code may only be used by licensed users of the CCS ////
//// C compiler. This source code may only be distributed to other ////
//// licensed users of the CCS C compiler. No other use, ////
//// reproduction or distribution is permitted without written ////
//// permission. Derivative programs created using this software ////
//// in object code form are not restricted in any way. ////
#IFNDEF __USB_HARDWARE__
#DEFINE __USB_HARDWARE__
//let the USB Stack know that we are using a PIC with internal USB peripheral
#DEFINE __PIC__ 1
#if ((getenv("DEVICE")=="PIC18F87J50") || (getenv("DEVICE")=="PIC18F86J55") || \
(getenv("DEVICE")=="PIC18F86J50") || (getenv("DEVICE")=="PIC18F85J50") || \
(getenv("DEVICE")=="PIC18F67J50") || (getenv("DEVICE")=="PIC18F66J55") || \
(getenv("DEVICE")=="PIC18F66J50") || (getenv("DEVICE")=="PIC18F65J50"))
#define __USB_87J50__
#define USB_TOTAL_BUFFER_SPACE ((int16)getenv("RAM")-0x500)
#define USB_MAX_NUM_ENDPOINTS 16
#elif ((getenv("DEVICE")=="PIC18F2450") || (getenv("DEVICE")=="PIC18F4450"))
#define __USB_4450__
#if ((USB_EP3_TX_SIZE + USB_EP3_RX_SIZE + USB_EP4_TX_SIZE + USB_EP4_RX_SIZE + \
USB_EP5_TX_SIZE + USB_EP5_RX_SIZE + USB_EP6_TX_SIZE + USB_EP6_RX_SIZE + \
USB_EP7_TX_SIZE + USB_EP7_RX_SIZE + USB_EP8_TX_SIZE + USB_EP8_RX_SIZE + \
USB_EP9_TX_SIZE + USB_EP9_RX_SIZE + USB_EP10_TX_SIZE + USB_EP10_RX_SIZE + \
USB_EP11_TX_SIZE + USB_EP11_RX_SIZE + USB_EP12_TX_SIZE +USB_EP12_RX_SIZE + \
USB_EP13_TX_SIZE + USB_EP13_RX_SIZE + USB_EP14_TX_SIZE + USB_EP14_RX_SIZE + \
USB_EP15_TX_SIZE + USB_EP15_RX_SIZE) > 0)
#error This driver only supports endpoints 0, 1 and 2 for this chip.
#endif
#define USB_MAX_NUM_ENDPOINTS 3
#define USB_TOTAL_BUFFER_SPACE (0x100 - USB_MAX_NUM_ENDPOINTS*8)
#elif ((getenv("DEVICE")=="PIC18F2455") || (getenv("DEVICE")=="PIC18F2550") || \
(getenv("DEVICE")=="PIC18F4455") || (getenv("DEVICE")=="PIC18F4550"))
#define USB_TOTAL_BUFFER_SPACE ((int16)0x300)
#elif ((getenv("DEVICE")=="PIC18F4553")) // PIC18F4553 PATCH
#define __USB_4553__ // PIC18F4553 PATCH
#define USB_TOTAL_BUFFER_SPACE ((int16)0x300) // PIC18F4553 PATCH
#define USB_MAX_NUM_ENDPOINTS 16 // PIC18F4553 PATCH
#else
#error Unknown PIC device, USB not supported in this library.
#endif
#ifndef USB_USE_FULL_SPEED
#define USB_USE_FULL_SPEED TRUE
#endif
#ifndef USB_CON_SENSE_PIN
#define USB_CON_SENSE_PIN 0
#endif
#if defined(__USB_4450__)
//due to limited ram, force max packet length to 8 for this chip
#define USB_MAX_EP0_PACKET_LENGTH 8
#else
#if USB_USE_FULL_SPEED==FALSE
//slow speed requires 8byte max packet size for endpoint 0
#DEFINE USB_MAX_EP0_PACKET_LENGTH 8
#else
//for full speed you can still use 8bytes, but 64 will be faster
#DEFINE USB_MAX_EP0_PACKET_LENGTH 64
#endif
#endif
#INCLUDE <usb.h>
#define USB_BUFFER_NEEDED (USB_EP0_TX_SIZE+USB_EP0_RX_SIZE+USB_EP1_TX_SIZE+USB_EP1_RX_SIZE+USB_EP2_TX_SIZE+USB_EP2_RX_SIZE+USB_EP3_TX_SIZE+USB_EP3_RX_SIZE+USB_EP4_TX_SIZE+USB_EP4_RX_SIZE+USB_EP5_TX_SIZE+USB_EP5_RX_SIZE+USB_EP6_TX_SIZE+USB_EP6_RX_SIZE+USB_EP7_TX_SIZE+USB_EP7_RX_SIZE+USB_EP8_TX_SIZE+USB_EP8_RX_SIZE+USB_EP9_TX_SIZE+USB_EP9_RX_SIZE+USB_EP10_TX_SIZE+USB_EP10_RX_SIZE+USB_EP11_TX_SIZE+USB_EP11_RX_SIZE+USB_EP12_TX_SIZE+USB_EP12_RX_SIZE+USB_EP13_TX_SIZE+USB_EP13_RX_SIZE+USB_EP14_TX_SIZE+USB_EP14_RX_SIZE+USB_EP15_TX_SIZE+USB_EP15_RX_SIZE)
#if (USB_BUFFER_NEEDED > USB_TOTAL_BUFFER_SPACE)
#error You are trying to allocate more memory for endpoints than the PIC can handle
#endif
#reserve 0x400:0x4FF
#else
#reserve 0x400:0x4FF+USB_BUFFER_NEEDED
#endif
#define debug_usb(a,b,c,d,e,f,g,h,i,j,k,l,m,n,o,p,q,r,s,t,u,v,w,x,y,z)
//#define debug_usb printf
//#define debug_putc putc_tbe
#define debug_display_ram(x,y)
void debug_display_ram(int8 len, int8 *ptr) {
int8 max=16;
debug_usb(debug_putc,"%U - ",len);
if (max>len) {max=len;}
while(max--) {
debug_usb(debug_putc,"%X",*ptr);
len--;
ptr++;
if (len) {debug_usb(debug_putc,"...");}
//if you are worried that the PIC is not receiving packets because a bug in the
//DATA0/DATA1 synch code, you can set this to TRUE to ignore the DTS on
//receiving.
#ifndef USB_IGNORE_RX_DTS
#define USB_IGNORE_RX_DTS FALSE
#endif
#ifndef USB_IGNORE_TX_DTS
#define USB_IGNORE_TX_DTS FALSE
#endif
//if you enable this it will keep a counter of the 6 possible errors the
//pic can detect. disabling this will save you ROM, RAM and execution time.
#ifndef USB_USE_ERROR_COUNTER
#define USB_USE_ERROR_COUNTER FALSE
#endif
#define USB_PING_PONG_MODE_OFF 0 //no ping pong
#define USB_PING_PONG_MODE_E0 1 //ping pong endpoint 0 only
#define USB_PING_PONG_MODE_ON 2 //ping pong all endpoints
//NOTE - PING PONG MODE IS NOT SUPPORTED BY CCS!
#ifndef USB_PING_PONG_MODE
#define USB_PING_PONG_MODE USB_PING_PONG_MODE_OFF
#endif
#if USB_USE_ERROR_COUNTER
int ERROR_COUNTER[6];
#endif
//---pic18fxx5x memory locations
#if defined(__USB_4550__) || defined(__USB_4450__) || defined(__USB_4553__) // PIC18F4553 PATCH
#byte UFRML = 0xF66
#byte UFRMH = 0xF67
#byte UIR = 0xF68
#byte UIE = 0xF69
#byte UEIR = 0xF6A
#byte UEIE = 0xF6B
#byte USTAT = 0xF6C
#byte UCON = 0xF6D
#byte UADDR = 0xF6E
#byte UCFG = 0xF6F
#define UEP0_LOC 0xF70
#else
#byte UFRML = 0xF60
#byte UFRMH = 0xF61
#byte UIR = 0xF62
#byte UIE = 0xF5C
#byte UEIR = 0xF63
#byte UEIE = 0xF5D
#byte USTAT = 0xF64
#byte UCON = 0xF65
#byte UADDR = 0xF5E
#byte UCFG = 0xF5F
#define UEP0_LOC 0xF4C
#endif
#byte UEP0 = UEP0_LOC
//#define USB_BUFFER (0x400 + (USB_MAX_NUM_ENDPOINTS*8)) //compiler doesnt support this
#if USB_MAX_NUM_ENDPOINTS==3
#define USB_BUFFER 0x418 //if you have an old compiler you will need to use this
#else
#error Define USB_BUFFER for the number of endpoints you have (0x400 + NUM*0x08)
#endif
#else
#define USB_BUFFER 0x500
#endif
#byte BD0STAT = 0x400
#byte BD0CNT = 0x401
#byte BD0ADRL = 0x402
#byte BD0ADRJ = 0x403
#define BD0STAT_LOC 0x400
#define BD0CNT_LOC 0x401
#define BD0ADRL_LOC 0x402
#define BD0ADRH_LOC 0x403
#define UEP(x) *(UEP0_LOC+x)
#BIT UIR_SOF = UIR.6
#BIT UIR_STALL = UIR.5
#BIT UIR_IDLE = UIR.4
#BIT UIR_TRN = UIR.3
#BIT UIR_ACTV = UIR.2
#BIT UIR_UERR = UIR.1
#BIT UIR_URST = UIR.0
#BIT UIE_SOF = UIE.6
#BIT UIE_STALL = UIE.5
#BIT UIE_IDLE = UIE.4
#BIT UIE_TRN = UIE.3
#BIT UIE_ACTV = UIE.2
#BIT UIE_UERR = UIE.1
#BIT UIE_URST = UIE.0
#bit UCON_PBRST=UCON.6
#bit UCON_SE0=UCON.5
#bit UCON_PKTDIS=UCON.4
#bit UCON_USBEN=UCON.3
#bit UCON_RESUME=UCON.2
#bit UCON_SUSPND=UCON.1
#if (USB_PING_PONG_MODE==USB_PING_PONG_MODE_OFF)
#define EP_BDxST_O(x) *(BD0STAT_LOC + x*8)
#define EP_BDxCNT_O(x) *(BD0CNT_LOC + x*8)
#define EP_BDxADR_O(x) *(int16 *)(BD0ADRL_LOC + x*8)
#define EP_BDxST_I(x) *(BD0STAT_LOC + 4 + x*8)
#define EP_BDxCNT_I(x) *(BD0CNT_LOC + 4 + x*8)
#define EP_BDxADR_I(x) *(int16 *)(BD0ADRL_LOC + 4 + x*8)
#else
#error Right now this driver only supports no ping pong
#endif
//See UEPn (0xF70-0xF7F)
#define ENDPT_DISABLED 0x00 //endpoint not used
#define ENDPT_IN_ONLY 0x02 //endpoint supports IN transactions only
#define ENDPT_OUT_ONLY 0x04 //endpoint supports OUT transactions only
#define ENDPT_CONTROL 0x06 //Supports IN, OUT and CONTROL transactions - Only use with EP0
#define ENDPT_NON_CONTROL 0x0E //Supports both IN and OUT transactions
//Define the states that the USB interface can be in
enum {USB_STATE_DETACHED=0, USB_STATE_ATTACHED=1, USB_STATE_POWERED=2, USB_STATE_DEFAULT=3,
USB_STATE_ADDRESS=4, USB_STATE_CONFIGURED=5} usb_state=0;
//--BDendST has their PIDs upshifed 2
#define USB_PIC_PID_IN 0x24 //device to host transactions
#define USB_PIC_PID_OUT 0x04 //host to device transactions
#define USB_PIC_PID_SETUP 0x34 //host to device setup transaction
#define USTAT_IN_E0 4
#define USTAT_OUT_SETUP_E0 0
#define __USB_UIF_RESET 0x01
#define __USB_UIF_ERROR 0x02
#define __USB_UIF_ACTIVE 0x04
#define __USB_UIF_TOKEN 0x08
#define __USB_UIF_IDLE 0x10
#define __USB_UIF_STALL 0x20
#define __USB_UIF_SOF 0x40
#define STANDARD_INTS 0x3F
#else
#define STANDARD_INTS 0x3D
#endif
#define __USB_UCFG_UTEYE 0x80
#if defined(__USB_4550__) || defined(__USB_4553__) // PIC18F4553 PATCH
#define __USB_UCFG_UOEMON 0x40
#endif
#define __USB_UCFG_UPUEN 0x10
#define __USB_UCFG_UTRDIS 0x08
#define __USB_UCFG_FSEN 0x04
#define __UCFG_VAL_ENABLED__ (__USB_UCFG_UPUEN | __USB_UCFG_FSEN | USB_PING_PONG_MODE)
#else
#define __UCFG_VAL_ENABLED__ (__USB_UCFG_UPUEN | USB_PING_PONG_MODE);
#endif
#define __UCFG_VAL_DISABLED__ 0x08
char usb_ep0_rx_buffer[USB_MAX_EP0_PACKET_LENGTH];
#locate usb_ep0_rx_buffer=USB_BUFFER
char usb_ep0_tx_buffer[USB_MAX_EP0_PACKET_LENGTH];
#locate usb_ep0_tx_buffer=USB_BUFFER+USB_MAX_EP0_PACKET_LENGTH
char usb_data_buffer[USB_TOTAL_BUFFER_SPACE-USB_MAX_EP0_PACKET_LENGTH-USB_MAX_EP0_PACKET_LENGTH];
#locate usb_data_buffer=USB_BUFFER+USB_MAX_EP0_PACKET_LENGTH+USB_MAX_EP0_PACKET_LENGTH
int8 __setup_0_tx_size;
Best Regards to all,
Bill |
